Thank you very much Andrea.
Then that might be the cause of the problem that I am having when trying to load localhost:8080/geoserver.
I removed/reinstalled Geoserver using port 8081 instead, and got the same
"NFO | jvm 1 | 2015/07/02 08:03:18 | 2015-07-02 08:03:18.507::WARN: failed SelectChannelConnector@anonymised.com:8081
INFO | jvm 1 | 2015/07/02 08:03:18 | java.net.BindException: Address already in use: bind"
I shutdown totally the firewall (windows server 2012 - IIS 8)
Geoserver is installed as a service and is listed as up and running.
When I try to run localhost:8081/geoserver I always get error 404 and the browser address changes automatically to
localhost:8081/geoserver/web which of course is not there.
TIA
JJ
On Thu, Jul 2, 2015 at 12:12 AM, jair santos <jairds@anonymised.com> wrote:
Hello everyone.
Does anybody knows what is the exception below from the wrapper.log?
Thanks
JJ
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:238)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | 2015-07-01 15:01:30.614::WARN: EXCEPTION
INFO | jvm 1 | 2015/07/01 15:01:30 | java.net.BindException: Address already in use: bind
It means there is already another program running on the same TCP port (normally that would be 8080, but you can change
it during installation)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
