Hi Jody,
Yes, I installed geoserver as a service. Why this would cause this warning?
thanks
JJ
Looks like it is a wrapper allowing a java application to be run as a windows service.
Jody Garnett
On 1 July 2015 at 15:12, jair santos <jairds@anonymised.com> wrote:
Hello everyone.
Does anybody knows what is the exception below from the wrapper.log?
Thanks
JJ
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:238)
INFO | jvm 1 | 2015/07/01 15:01:30 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | 2015-07-01 15:01:30.614::WARN: EXCEPTION
INFO | jvm 1 | 2015/07/01 15:01:30 | java.net.BindException: Address already in use: bind
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.Net.bind0(Native Method)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.Net.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:205)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:304)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.jetty.Server.doStart(Server.java:233)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
INFO | jvm 1 | 2015/07/01 15:01:30 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.invokeMain(Main.java:183)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.start(Main.java:497)
INFO | jvm 1 | 2015/07/01 15:01:30 | at org.mortbay.start.Main.main(Main.java:115)
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
