Hmm… it seems port 8081 is also busy… not sure what to add, the message is exactly the same as before.
This seems not to be the case. When I run the Resource Monitor I can see 8081 in the list of listening ports. Shutting down geoserver immediatley remove the port from the list. Therefore, the port is free.
The windows server is 64 bits. I read somewhere in the user list that both java and geoserver must be 32 bits. I wonder that it might have some issue related with this.
I had server-jre-7u80-windows-x64 , then I removed and installed jre-7u79-windows-i586 instead.
thanks.
JJ
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
