[Geoserver-users] Wrapper exception
Hi Jair,
have you tried to start GeoServer staight from the command line, instead of running it as a service? Does it start?
No, I haven’t. I did it now and it worked smoothly. Thank you for that Stefano!
The question now is why it doesn’t work when started as a service?
Might be because the install is not passing the proper parameter?
JJ.
