Hello,
I have taken look in the Database.
There is stored the following value 23.04.2007 15:24:29.
If I choose Date or Datetime as Datatype in the DescripeFeatureType-Response
does not have any effect.
I can't understand why Java should switch the Day-Value on this Date.
Do geoserver switch the locale by itself?
- Tim
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet: Sonntag, 17. Juni 2007 22:06
An: Tim Englich
Cc: geoserver-users@lists.sourceforge.net; aaime@anonymised.com
Betreff: Re: [Geoserver-users] Wrong Date-Value using Oracle-Datastore
Not quite, the problems i have run into (and i can only speak from
postgis) is when a timezone is stored with the date in the database. For
instance a time with a +2 zone offset:
2007-06-20 02:00+02:00
When this date gets read into java it is stored internally in the native
timzone for that locale, so for me the date becomes:
2007-06-19 16:00-08:00
SO depending on how this date gets written out and read back in it could
potentially lose the timezone.
Its tough to say though without having a database to test with. I know
andrea has an oracle install around, perhaps he can do a little test for us.
-Justin
Tim Englich wrote:
Hello,
Justin do you think that there e.g. will be subtract an hour from the
recieved date?
This will mean that 2007-04-23 will be converted to 2007-04-22 23:00:00 ?
This would be horrible.Has anyone some experiences to german date values and geoserver?
Tim
Von: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net]Im Auftrag von Tim
Englich
Gesendet: Freitag, 15. Juni 2007 21:05
An: Justin Deoliveira
Betreff: Re: [Geoserver-users] Wrong Date-Value using Oracle-DatastoreHello Justin,
we have this problems on different Systems.When there is a timezone attached it would be central european time. Our
server runs with the same timezone.do you know somethink about the method which converts the Date to String?
Tim
Gesendet: Fr 15.06.2007 20:28
An: Tim Englich
Betreff: Re: [Geoserver-users] Wrong Date-Value using Oracle-DatastoreHi Tim,
Does the date in the database have a timezone attached to it? If so when
the date gets pulled into java it will be converted to the local time
zone. Then probably getting written out without the timezone info
attached. Just a guess.-Justin
Tim Englich wrote:
Hello everybody,
we think have found an issue using the Oracle Datastore.
We use the 1.5.0 Release of Geoserver
We get a Date-Value in the response which is one Day wrong.We get 2007-04-22 the Value in the Database is 2007-04-23.
When we use the Oracle-DataStore directly everything works fine.
Might this issue occurs while creating the output?Our System is like this:
Oracle 9.2 Database (We use JDBC-Connection)
Java Version 1.6.0
Servlet Container apache-tomcat-5.5.20Has anyone an idea how to solve this issue?
Tim
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
