[Geoserver-users] Wrong GML schemaLocation
when doing a WFS describeFeatureType, the response insists that the gml namespace is
http://x.x.x.x:8080/geoserver/wfs/schemas/gml/3.1.1/base/gml.xsd”. This yields a “no mapping for”
-error, since geoserver probably tries to feed the request into the dispatcher.
I believe the correct URI is “http://x.x.x.x:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd”,
at least that gives me the schema ? (removing the wfs-part).
Is there any way to get around this ?
Oyvind Idland
Hi Oyvind,
You are correct about the URI. There is no real easy way to get around this. Which version of GeoServer are you using?
Oyvind Idland wrote:
"http://x.x.x.x:8080/geoserver/wfs/schemas/gml/3.1.1/base/gml.xsd"\. This yields a "no mapping for"
I believe the correct URI is "http://x.x.x.x:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd",
Oyvind Idland
!DSPAM:4007,48527851316748992556831!
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
thanks for fast response.
I am currently using 1.6.4-stable.
Is this issue fixed in the 1.7.0 beta1 version ?
On Fri, Jun 13, 2008 at 4:47 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Oyvind,
Oyvind Idland
It’s the best place to buy or sell services for
Justin Deoliveira
Ok, i have verified this problem. And it appears both on 1.6.4 and 1.7.0-beta1. I am filing a bug report for this:
http://jira.codehaus.org/browse/GEOS-1989
I should also note that this is only an issue with wfs 1.1, a dft request in wfs 1.0 does the correct thing.
Thanks for the bug report. The fix is trivial so i will fix it quite soon. If you want to grab a nightly build of 1.6.x feel free to do so. It will be up tommorrow, or i can generate you one manually if you want.
-Justin
On Fri, Jun 13, 2008 at 4:47 PM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Hi Oyvind,
        "http://x.x.x.x:8080/geoserver/wfs/schemas/gml/3.1.1/base/gml.xsd&quot;\.
        the dispatcher.
        "http://x.x.x.x:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;,
        Oyvind Idland
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Justin Deoliveira
!DSPAM:4007,48528a4b36841012714783!
Justin Deoliveira
Thanks alot, appreciated ! :smiley:
  • Oyvind
On Fri, Jun 13, 2008 at 5:25 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
On Fri, Jun 13, 2008 at 4:47 PM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
Hi Oyvind,
the dispatcher.
Oyvind Idland
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
– Justin Deoliveira
Justin Deoliveira
