[Geoserver-users] Wrong native crs
Hello everybody,
I have a problem on native srs on my geoserver 2.3.2
I loaded many raster grid in asc format created in epsg:32633.
Geoserver recognize as native srs 404000.
Of course I set the srs handling as ‘declared’, and declared is EPSG:32633.
However this workaround doesn’t work for me my aim, because I have the
grid rightly projected on my webGIS, but the downloading tool
give me a geoTIFF without any SRS.
I would like to know if there is a way to handle this issue by geoserver.
I mean is it possible to allow geoserver to recognize the right native SRS?
Thank you
Eugenio
Ciao Eugenio,
do you have gdalinfo installed on the same machine?
Could you check what it reports about some of the rasters?
Stefano
2014-10-31 15:34 GMT+01:00 Eugenio Trumpy <frippe12573@anonymised.com>:
Hello everybody,
Thank you
Eugenio
Geoserver-users mailing list
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Ciao Stefano,
I just checked on one asc, I got this output:
gdalinfo /dati/geoserver_data/coverages/v_raster/raster_grid.asc
Driver: AAIGrid/Arc/Info ASCII Grid
Files: /dati/geoserver_data/coverages/v_raster/raster_grid.asc
Size is 284, 186
Coordinate System is `’
Origin = (272500.000000000000000,4240500.000000000000000)
Pixel Size = (1000.000000000000000,-1000.000000000000000)
Corner Coordinates:
Upper Left ( 272500.000, 4240500.000)
Lower Left ( 272500.000, 4054500.000)
Upper Right ( 556500.000, 4240500.000)
Lower Right ( 556500.000, 4054500.000)
Center ( 414500.000, 4147500.000)
Band 1 Block=284x1 Type=Float32, ColorInterp=Undefined
NoData Value=99999
Actually I see that Coordinate system is empty.
Is there a way in geoserver to complete the asc info?
Regards
Eugenio
Date: Fri, 31 Oct 2014 15:40:25 +0100
Subject: Re: [Geoserver-users] Wrong native crs
To: frippe12573@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Ciao Eugenio,
Stefano
41.95581N 12.52854E
Hello everybody,
Thank you
Eugenio
