[Geoserver-users] Wrong WKT String for CH1903/LV03 Projection (ESPG:21781)
Hello
I think I found a wrong WKT string for CH1903/LV03 Projection
(ESPG:21781). With the actual definition inside espg.properties you've
got a wrong display from map (you will see an example here:
http://www.zubi.li/files/schweiz.jpg). With the WKT string from
PostGIS the same source will displayed correct!!
Who can forward this mail to the correct person who can correct this
in next release? Thank you.
Regards, Thomas
2006/10/30, Thomas Zuberbuehler <tzuberbuehler@anonymised.com>:
I add your wkt string to epsg.properties, compress it again and
restart my server. But nothing happened. If I create a new feature
type with geoserver webinterface I will get:
Could not find a definition for: EPSG:45555
Thomas
2006/10/30, Alexander Petkov <greenkov@anonymised.com>:
> On 10/30/06, Thomas Zuberbuehler <tzuberbuehler@anonymised.com> wrote:
> > Following the wkt string for CH1903/LV03 (EPSG:21781) from PostGIS.
> > Its a different one to 21781 from GeoServer.
> > <code>
> > PROJCS["CH1903 / LV03",
> > GEOGCS["CH1903",
> > DATUM["CH1903",
> > SPHEROID["Bessel 1841",6377397.155,299.1528128,
> > AUTHORITY["EPSG","7004"]
> > AUTHORITY["EPSG","6149"]
> > PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
> > UNIT["degree",0.01745329251994328,
> > AUTHORITY["EPSG","9122"]
> > AUTHORITY["EPSG","4149"]
> > PROJECTION["Hotine_Oblique_Mercator"],
> > PARAMETER["latitude_of_center",46.95240555555556],
> > PARAMETER["longitude_of_center",7.439583333333333],
> > PARAMETER["azimuth",90],
> > PARAMETER["rectified_grid_angle",90],
> > PARAMETER["scale_factor",1],
> > PARAMETER["false_easting",600000],
> > PARAMETER["false_northing",200000],
> > UNIT["metre",1,AUTHORITY["EPSG","9001"]],
> > AUTHORITY["EPSG","21781"]
> > +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333
> > +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs
> > </code>
> The last 2 lines are proj4 text, you do not need that. Probably that's
> why it didn't parse.
> Just use the srtext string from the spatial_ref_sys table. You can add
> this to the epsg.properties file:
> 45555=PROJCS["CH1903_LV03",GEOGCS["GCS_CH1903",DATUM["D_CH1903",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Hotine_Oblique_Mercator_Azimuth_Center"],PARAMETER["False_Easting",600000],PARAMETER["False_Northing",200000],PARAMETER["Scale_Factor",1],PARAMETER["Azimuth",90],PARAMETER["Longitude_Of_Center",7.439583333333333],PARAMETER["Latitude_Of_Center",46.95240555555556],UNIT["Meter",1]]
> Explanation:
> 45555 is a code that I came up with. Change it to something that makes
> sense to you.
> Also, I am not certain if the entry really needs to be all on one
> line--you can try it and tell me.
> Alex
Thomas Zuberbuehler
http://www.zubi.li
Thomas Zuberbuehler
http://www.zubi.li
Thomas Zuberbuehler
http://www.zubi.li
Thomas Zuberbuehler ha scritto:
Hello
If you're quick we may be able to include it in the
next release, yes... please post the fixed wkt string.
We'll have to check it against the latest EPSG database too, curious
to know if the error is in the official db too.
Andrea Aime
The WKT string for CH1903/LV03
21781=PROJCS["CH1903_LV03",GEOGCS["GCS_CH1903",DATUM["D_CH1903",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Hotine_Oblique_Mercator_Azimuth_Center"],PARAMETER["False_Easting",600000],PARAMETER["False_Northing",200000],PARAMETER["Scale_Factor",1],PARAMETER["Azimuth",90],PARAMETER["Longitude_Of_Center",7.439583333333333],PARAMETER["Latitude_Of_Center",46.95240555555556],UNIT["Meter",1],AUTHORITY["EPSG","21781"]]
See also Thread "Try to add/correct a Projection in Geoserver"!
Thank you.
Regards Thomas
2006/10/30, Andrea Aime <aaime@anonymised.com>:
> Hello
Andrea Aime
Thomas Zuberbuehler
http://www.zubi.li
Do you know if this issue has been fixed? I looked manually in the "epsg.properties" file on geotools trunk and found no significant difference except for the object names ("CH1903 / LV03" vs "CH1903_LV03", etc.).
  Martin
Bonjour Martin
Since I have replace this WKT string in my working copy of GeoServer I
can transform my geodata without any problems. Before there was a
wrong transformation. See also thread discussion ("Try to add/correct
a Projection in Geoserver") with Alexander.
But I'm not 100% sure that this string is absolutly correct. As you
see in the discussion, the WKT string has the origin out of PostGIS.
Saluer de Suisse,
Thomas
2006/11/25, Martin Desruisseaux <martin.desruisseaux@anonymised.com>:
        Martin
Thomas Zuberbuehler
http://www.zubi.li
From MAILER-DAEMON Sat Nov 25 12:16:36 2006
Date: Sun, 26 Nov 2006 03:34:27 +0700
X-MDaemon-Deliver-To: geoserver-users@lists.sourceforge.net
Message-ID: <MDAEMON0018200611260334.AA3427734@anonymised.com>
Mime-Version: 1.0
X-Actual-From: bhs@anonymised.com
X-Return-Path: <>
X-Spam-Score: 0.2 (/)
X-Spam-Report: Spam Filtering performed by sourceforge.net.
  See http://spamassassin.org/tag/ for more details.
  Report problems to
  http://sf.net/tracker/?func­d&amp;group\_id=1&amp;atid=200001
  0.2 NO_REAL_NAME From: does not include a real name
Subject: [Geoserver-users] Geoserver-users Digest, Vol 6, Issue 42
X-BeenThere: geoserver-users@lists.sourceforge.net
X-Mailman-Version: 2.1.8
Precedence: list
Reply-To: geoserver-users@lists.sourceforge.net
List-Id: Help for geoserver users <geoserver-users.lists.sourceforge.net>
List-Unsubscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;, <mailto:geoserver-users-request@lists.sourceforge.net?subject=unsubscribe>
List-Archive: <http://sourceforge.net/mailarchive/forum.php?forum=geoserver-users&gt;
List-Post: <mailto:geoserver-users@lists.sourceforge.net>
List-Help: <mailto:geoserver-users-request@lists.sourceforge.net?subject=help>
List-Subscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;, <mailto:geoserver-users-request@lists.sourceforge.net?subject=subscribe>
X-List-Received-Date: Sat, 25 Nov 2006 20:16:36 -0000
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 8bit
Deputy Chief of SCIREN
http://www2.hcm.ciren.gov.vn/jvnwebgis
From MAILER-DAEMON Sun Nov 26 12:20:41 2006
Date: Mon, 27 Nov 2006 03:38:32 +0700
Message-ID: <MDAEMON0022200611270338.AA3832671@anonymised.com>
Mime-Version: 1.0
X-Return-Path: <>
  Report problems to
  http://sf.net/tracker/?func=add&group_id=1&atid=200001
Subject: [Geoserver-users] Geoserver-users Digest, Vol 6, Issue 43
Precedence: list
X-List-Received-Date: Sun, 26 Nov 2006 20:20:42 -0000
