[Geoserver-users] X.509 Authentication in Geoserver 2.4.x
I have been trying to set up https support for geoserver and have it working for tomcat but in geoserver, the tutorial in the docs online seem to be either not referencing prerequisite setup or aren’t correct.
Tutorial found here: http://docs.geoserver.org/stable/en/user/security/tutorials/cert/index.html
First issue is with step 8. There is no role “ROLE_ADMINISTRATOR” or “ROLE_GROUP_ADMIN”. There is only “ADMIN” and “GROUP_ADMIN”. Fine, they’re similar to the two defined in the docs so I set it to “ADMIN”.
Second issue (numbering doesn’t show two digits by the way) is in step 16. Under the “Filter Chains” section, there is no Request Type or dropdown setting. There isn’t even a filter chain called “Web UI”.
How is this supposed to work? Is the documentation correct and I missed some geoserver setup somewhere? Thanks for any help.
  • Stephen
Security is a bit of a choose your own adventure in terms of defining roles and users. You are intended to define roles that match your organisation’s structure after all.
The role administrator and role group admin can be consider the two levels of access available for use of the geoserver administration web application. You can nominate any of your roles to have these powers as appropriate.
So I may make a “team_lead” group and assign it “group_admin”. That way a user given team_lead status would have the ability to login to just the security section of GeoServer. They would not be able to publish new data, but they would be able to manage their team members.
Hope that helps,
Jody
Jody Garnett
On Wed, Mar 19, 2014 at 4:42 AM, Stephen Ranger <sanosuke001@anonymised.com> wrote:
  • Stephen
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
Geoserver-users mailing list
Hi Stephen,
unfortunately the security related documentation is not updated to latest developments in many parts.
2014-03-18 18:42 GMT+01:00 Stephen Ranger <sanosuke001@anonymised.com>:
Yes, you can safely use ADMIN and GROUP_ADMIN.
The UI has changed a bit, you don’t have a dropdown anymore, replaced by a table. The old “Web UI” dropdown choice is now the “web” table row, click on the link to configure it.
  • Stephen
Thanks for the update.
On Fri, Mar 21, 2014 at 4:53 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Stephen,
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
  • Stephen
