fgravin
September 17, 2012, 9:46am
1
I’ve defined a complex feature mapping file, with some ReferencedType inside.
Mapping file :
xlink
[http://www.w3.org/1999/xlink](http://www.w3.org/1999/xlink)
xlink:href
if_then_else(isNull(boundary), Expression.NIL, strConcat('urn:x-inspire:specification:gmlas:AdministrativeUnit:3.0:', boundary))
This gives as response
<au:boundary href=“urn:x-inspire:specification:gmlas:AdministrativeUnit:3.0:8269”/>
The problem is that href is encoded but not xlink:href !
And in the top element of the xml response, the namespace is not declared ! (should have xmlns:xlink=“http://www.w3.org/1999/xlink ”)
I’m using master branch of geotools and geoserver…
Do you know where to look in order to make xlink encoding working properly ?
Ty
Florent Gravin
CampToCamp - Chambéry
0479444492
fgravin
September 17, 2012, 1:22pm
2
I’ve found that xlink:href is well encoded if you use WFS 1.1.0 and not if you use 2.0.0 (encode href instead).
Still wondering why
On Mon, Sep 17, 2012 at 11:46 AM, Florent Gravin <florent.gravin@anonymised.com > wrote:
Mapping file :
xlink
xlink:href
Ty
Florent Gravin
0479444492
Florent Gravin
0479444492
Hi Florent,
App-schema doesn't support WFS 2.0.0, however you can use WFS 1.1.0 with GML
3.2 by specifying outputFormat=gml32 and version=1.1.0.
With gml 3.2, you need to specify secondary namespaces in a separate
namespace.xml and workspace.xml as shown in
http://docs.geoserver.org/stable/en/user/data/app-schema/supported-gml-versions.html#secondary-namespace-for-gml-3-2-1-required .
Try specifying namespace.xml and workspace.xml for xlink.
I hope that helps.
Rini
View this message in context: http://osgeo-org.1560.n6.nabble.com/xlink-ref-not-well-encoded-in-WFS-response-app-schema-tp5002307p5004518.html
I noticed a similar problem with WFS version 2.0.0. I'm using app-schema
configuration and get schema resolution with the following WFS GetFeature
request GetFeature-AppSchema.xml
<http://osgeo-org.1560.x6.nabble.com/file/n5060964/GetFeature-AppSchema.xml> ;
http://localhost:8080/geoserver/wfs?service=wfs&version=1.1.0&request=GetFeature&typeName=HeatFlow:HeatFlow
But when I try the version 2 request:
http://localhost:8080/geoserver/wfs?service=wfs&version=2.0.0&request=GetFeature&typeName=HeatFlow:HeatFlow&maxFeatures=10
I get the error: "The prefix "null" for element
"null:Envelope" is not bound."
Is there a time frame for a fix, where the WFS version 2.0.0 will work with
app-schemas?
Christy
View this message in context: http://osgeo-org.1560.x6.nabble.com/xlink-ref-not-well-encoded-in-WFS-response-app-schema-tp5002307p5060964.html
Hi Christy,
I raised a JIRA issue here: https://jira.codehaus.org/browse/GEOT-4894
I will try my best to have a look this month, and see if the issue is
related with xlink.
Rini
View this message in context: http://osgeo-org.1560.x6.nabble.com/xlink-ref-not-well-encoded-in-WFS-response-app-schema-tp5002307p5161027.html
