[Geoserver-users] XSLT plugin causes Multiple responses Exception
When we run geoserver-2.3.1 with XSLT-plugin on Classpath all GetFeature requests (notice: without XSLT Transformation) end up with a WFS ServiceException saying:
java.lang.RuntimeException: Multiple responses: (class org.geoserver.wfs.request.FeatureCollectionResponse$WFS11)
If the xslt-plugin is removed and geoserver restarted, WFS works just fine again.
Any ideas? Cheers rudi
On Tue, May 7, 2013 at 1:30 PM, Hochmeister Rudolf <
rudolf.hochmeister@anonymised.com> wrote:
again.
No idea why, given that XSLT module is full of tests, but I've just
confirmed it and opened a ticket:
http://jira.codehaus.org/browse/GEOS-5804
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, May 9, 2013 at 6:47 PM, Andrea Aime <andrea.aime@anonymised.com>wrote:
fine again.
Ok, managed to reproduce the issue and fix it, but the issue pops up only
if the xslt module is there,
but has no configuration files, they are misplaced, or using the wrong
syntax.
I've modified the module not to misbehave even if the configuration is
missing or broken,
and updated the docs so that they are hopefully easier to understand.
Can anybody double check the module from tomorrow's nightly build (May 15)?
http://gridlock.opengeo.org/geoserver/2.3.x/
Ing. Andrea Aime
@geowolf
Technical Lead
