Is it possible to create a GeoServer layer against an Oracle table that has only X and Y numeric columns?
(This seems like it might provide another potential solution to the issue of reducing Oracle query data size).
On Tue, Mar 10, 2015 at 7:47 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
has only X and Y numeric columns?(This seems like it might provide another potential solution to the issue
No, it is not possible. I started working on a possible solution some time
ago via the TransformFeatureSource,
but it's quite more general than just transforming two x and y into a
Point, which makes it somehow harder
to hook up (it's in the "non trivial" realm, otherwise I would have already
hooked it up in my spare time).
Generally speaking though, whatever you do, you'll need to create a UI and
configuration allowing the
user to specify which columns to use, and which crs the resulting point is
in... and whatever solution
you approach, handle the problem of transforming a generic spatial filter
against the point, towards
something that talks x and y instead (this part of the problem is not
solved in TransformDataStore
yet, but would not be too hard to add)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I figured that was the case, but thought I’d ask.
As a variation of this I tried converting the Oracle geometry into WKT and then convert that back into a geometry in the SLD using the geomFromWKT filter function. However, this failed with the "Rendering process failed Unable to transform referenced envelope, crs has not yet been provided. " error. I don’t suppose there’s any way to force a SRID into a geometry read from WKT? Does GeoServer support the EWKT SRID syntax by any chance?
On Tue, Mar 10, 2015 at 1:21 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
No, it is not possible. I started working on a possible solution some time ago via the TransformFeatureSource,
but it’s quite more general than just transforming two x and y into a Point, which makes it somehow harder
to hook up (it’s in the “non trivial” realm, otherwise I would have already hooked it up in my spare time).
Generally speaking though, whatever you do, you’ll need to create a UI and configuration allowing the
user to specify which columns to use, and which crs the resulting point is in… and whatever solution
you approach, handle the problem of transforming a generic spatial filter against the point, towards
something that talks x and y instead (this part of the problem is not solved in TransformDataStore
Ing. Andrea Aime
@geowolf
Technical Lead
Answering my own question, I see that geomFromWKT does NOT support EWKT. It would be fairly easy to write a geomFromEWKT function, of course.
Would this be all that is needed to get WKT to work as the source of the SLD element? If so, I might give this a go.
On Tue, Mar 10, 2015 at 1:50 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Or it might be simpler and neater to have a function
geomFromWKT_SRID(String wkt, int srid)
After a bit of code browsing it looks as thought this might not be sufficient to get this to work though?
On Tue, Mar 10, 2015 at 1:55 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Mar 10, 2015 at 9:50 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
I figured that was the case, but thought I'd ask.
then convert that back into a geometry in the SLD <Geometry> using the
been provided. " error. I don't suppose there's any way to force a SRID
Regardless of the conversion issues, the main problem I see is that you'd
basically have to include
extra filters to actually leverage the indexes you might have in your x/y
columns to avoid loading
all the data for nothing?
Besides, wouldn't GeoServer see the table as a geometryless one (as wkt is
just a string to GeoServer)?
And in this case, it should just refuse the publish the layer on the WMS
protocol?
Ing. Andrea Aime
@geowolf
Technical Lead
Well, yes… I had thought about those issues, but wanted to see how far it was possible to go with current implementation.
I’ve worked on some projects where we’ve found that for point data it’s faster to use X and Y columns with standard B-tree indexes, rather than spatial data. In that case we ended up using a custom rendering engine for the point layer. But it would be nifty if GeoServer was able to provide this capability. Not something I have funding for right now though.
On Wed, Mar 11, 2015 at 2:17 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Regardless of the conversion issues, the main problem I see is that you’d basically have to include
extra filters to actually leverage the indexes you might have in your x/y columns to avoid loading
Besides, wouldn’t GeoServer see the table as a geometryless one (as wkt is just a string to GeoServer)?
And in this case, it should just refuse the publish the layer on the WMS protocol?
Ing. Andrea Aime
@geowolf
Technical Lead
