Clearly EPSG:4258 should use lat-lon (north-east) order in all places if it is GML3. Thus your filter is right and the response wrong.
I wonder the first wfs:boundedBy. How can we know that it is using EPSG:4258 if it comes without srsName?
gml:lowerCorner46.34715 0.05296</gml:lowerCorner>
gml:upperCorner48.94105 3.12903</gml:upperCorner>
</gml:Envelope>
</wfs:boundedBy>
-Jukka Rahkonen-
Florent Gravin wrote:
I’ve read the geoserver topic, maybe XY has to be inverted, but whatever it should be inverted in all situation ? i mean in the GetFeatureResponse, and in my filterRequest.
For exemple :
fes:Filter
fes:BBOX
fes:ValueReferenceau:geometry</fes:ValueReference>
<gml:Envelope srsName=“EPSG::4258”>
gml:lowerCorner1.32709 48.49261</gml:lowerCorner>
gml:upperCorner1.37412 48.52348</gml:upperCorner>
</gml:Envelope>
</fes:BBOX>
</fes:Filter>
will give the response :
<wfs:FeatureCollection numberMatched=“unknown” numberReturned=“1” timeStamp=“2012-11-23T09:32:22.726Z” xsi:schemaLocation=“http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd urn:x-inspire:specification:gmlas:AdministrativeUnits:3.0 file:/home/fgravin/dev/ign/igngeoserver/data/nuts/workspaces/au/au_AdministrativeUnits/AdministrativeUnits.xsd”>
</gml:Envelope>
</wfs:boundedBy>
<au:AdministrativeUnit gml:id=“FR2400000000”>
<gml:Envelope srsDimension=“2” srsName=“EPSG:4258”>
</gml:Envelope>
</gml:boundedBy>
XY are not in the same order in the request and in the response.
My investigations lead me further :
It is in Object visit(BBOX filter, Object extraData) {
This is where it try to retrieve the targetCrs, from the propertyName, considering the featureType.
Seems it works well with Tasmania simpleFeatureType and topp:the_geom.
But in my case, i am using complexFeatureType and maybe the AttributeDescriptor at = (AttributeDescriptor) propertyName.evaluate(featureType); cannot retrieve properly the CRS from complexFeature.
Either it is a bug from app-schema, or i have something to specify in my schema to match the propertyName and the CRS somewhere i don’t know
do you have any idea ?
thanks
On Thu, Nov 22, 2012 at 6:30 PM, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
On Thu, Nov 22, 2012 at 5:50 PM, Florent Gravin <florent.gravin@anonymised.com> wrote:
My GetFeature response gives me :
gml:lowerCorner47.57657 3.38328</gml:lowerCorner>
gml:upperCorner50.1692 5.89086</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
If i want to make a WFS request with filter BBOX, i have to switch long lat to make it work :
gml:lowerCorner3.38328 47.57657</gml:lowerCorner>
gml:upperCorner5.89086 50.1692</gml:upperCorner>
</gml:Envelope>
I debug into WFSReprojectionUtil.normalizeFilterCRS(filter, source.getSchema(), declaredCRS);
where the convertion could be done
I’ve tested for Tasmania default layer that is in EPSG:4326, i used the same order to make the BBOX filter work … anyway i’ve heard 4326 has inverted XY …
Any way my question is :
Whatever the projection is, should the reponse and the filter envelope XY order HAVE TO be the same ?
Is there a bug somewhere ?
It’s difficult to tell, you’re not giving us enough information.
Please have a look here: http://docs.geoserver.org/latest/en/user/services/wfs/basics.html#axis-ordering
And then report again with the full request and enough of each response so that we can
look into it
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Florent Gravin
Camptocamp - Chambéry
0479444492
