[Geoserver-users] XYZ schema of GEOSERVER GWC TMS
OSM is using the same tile naming schema than Google maps while TMS specification defines a different schema. There is not really a thing “OSM like TMS” because it is not TMS. I believe that you can get help from https://help.openstreetmap.org/ and from the OSM wiki
http://wiki.openstreetmap.org/wiki/TMS
https://alastaira.wordpress.com/2011/07/06/converting-tms-tile-coordinates-to-googlebingosm-tile-coordinates/
-Jukka Rahkonen-
p.santin fintel wrote:
I noticed this using a client that expects a TMS that works like OSM:
these 2 urls show the same area of the world
OSM like TMS:
http://otile3.mqcdn.com/tiles/1.0.0/osm/2/2/1.png
GEOSERVER GWC TMS
http://sdi.georchestra.org/geoserver/gwc/service/tms/1.0.0/nasa%3Anight_2012@anonymised.com%3A3857@anonymised.com/2/2/2.png
As you will notice the XYZ schema at the end of url is different: 2/2/1 in the 1st case and 2/2/2 in second case
That causes a lot of troubles using a TMS from geoserver with a client that expects it working like OSM.
Is there any way to make geoserver TMS work as OSM?
if this is the case, it would not be hard to add a “osm” service endpoint to GeoWebCache, it could
be loosely adapted from the gmaps ones, which I guess already has the right x/y/z mapping, although
it’s using a different URL scheme:
http://geowebcache.org/docs/current/services/gmaps.html
Code here:
https://github.com/GeoWebCache/geowebcache/tree/master/geowebcache/gmaps/src
On Thu, Nov 5, 2015 at 1:55 PM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
OSM like TMS:
GEOSERVER GWC TMS
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
