[Geoserver-users] YSLD Styling Help Needed
I am trying to create a style that uses line casings to deferinate highway types and surface types.
The two types of highways appear as the correct color. But the surface line is always white. (White is the color used for a null value in surface.) The legend created geoserver is correct.
I’m using geoserver 2.10-snapshot
My data looks has name, highway, and surface fields.
Any suggestions on how to fix?
Thanks in advance,
Clifford
My YSLD script:
define: &track ‘#4E302F
define: &unclassified ‘#477443
define: &gravel ‘#2B4428
define: &asphalt ‘#6E7B8B
define: &paved ‘#544B8D
define: &concrete ‘#7FB299
title: ‘USFS Roads’
feature-styles:
  • name: highway
    rules:
  • name: unclassified
    scale: [‘32000.0’, max]
    filter: ${highway = ‘unclassified’}
    symbolizers:
  • line:
    stroke-color: *unclassified
    stroke-width: 3
    scale: [min, ‘32000.0’]
    symbolizers:
  • line:
    stroke-width: 7
  • name: track
    filter: ${highway = ‘track’}
    symbolizers:
  • line:
    stroke-color: *track
    stroke-width: 3
  • name: track
    symbolizers:
  • line:
    stroke-width: 7
  • name: surface
    rules:
  • name: gravel
    filter: ${surface = ‘gravel’}
    symbolizers:
  • line:
    stroke-color: black
    stroke-width: 3
  • name: asphalt
    filter: ${surface = ‘asphalt’}
    symbolizers:
  • line:
    stroke-color: *asphalt
    stroke-width: 3
  • name: paved
    filter: ${surface = ‘paved’}
    symbolizers:
  • line:
    stroke-color: *paved
    stroke-width: 3
  • name: concrete
    filter: ${surface = ‘concrete’}
    symbolizers:
  • line:
    stroke-color: *concrete
    stroke-width: 3
  • name: unknown
    filter: ${surface is null}
    symbolizers:
  • line:
    stroke-color: white
    stroke-width: 3
  • name: label
    rules:
  • scale: [min, ‘32000.0’]
    symbolizers:
  • line:
    stroke-color: ‘#FFFFFF
    stroke-width: 4
    stroke-linejoin: mitre
    stroke-linecap: round
    symbolizers:
  • text:
    label: ${street}
    fill-color: ‘#FFFFFF
    font-family: Times New Roman
    font-size: 12
    font-style: Normal
    font-weight: bold
    placement: line
    halo:
    fill-color: ‘#000000
    radius: 1
    offset: 10
    x-followLine: true
    x-group: true
@osm_seattle
osm_seattle.snowandsnow.us
OpenStreetMap: Maps with a human touch
Hi Clifford,
After modifying your style to fit some sample data I had, I think I found the problem - In your label feature-type, you have an always active white line (for scales less than 32000):
  • name: label
    rules:
    symbolizers:
  • line:
    stroke-width: 4
    symbolizers:
  • text:
    label: ${street}
    font-size: 12
    font-style: Normal
    font-weight: bold
    placement: line
    halo:
    radius: 1
    offset: 10
    x-followLine: true
    x-group: true
If this isn’t the issue, I have one other suggestion - YSLD is case-sensitive, so double-check the case of your properties (e.g. surface) and the values you are comparing them with.
Torben
On Thu, Mar 22, 2018 at 12:26 PM, Clifford Snow <clifford@anonymised.com> wrote:
Thanks in advance,
Clifford
My YSLD script:
title: ‘USFS Roads’
feature-styles:
  • name: highway
    rules:
    symbolizers:
  • line:
    stroke-width: 3
    symbolizers:
  • line:
    stroke-width: 7
  • name: track
    symbolizers:
  • line:
    stroke-width: 3
  • name: track
    symbolizers:
  • line:
    stroke-width: 7
  • name: surface
    rules:
  • name: gravel
    symbolizers:
  • line:
    stroke-color: black
    stroke-width: 3
  • name: asphalt
    symbolizers:
  • line:
    stroke-width: 3
  • name: paved
    symbolizers:
  • line:
    stroke-width: 3
  • name: concrete
    symbolizers:
  • line:
    stroke-width: 3
  • name: unknown
    symbolizers:
  • line:
    stroke-color: white
    stroke-width: 3
  • name: label
    rules:
    symbolizers:
  • line:
    stroke-width: 4
    symbolizers:
  • text:
    label: ${street}
    font-size: 12
    font-style: Normal
    font-weight: bold
    placement: line
    halo:
    radius: 1
    offset: 10
    x-followLine: true
    x-group: true
@osm_seattle
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
