Another issue, GeoJSON coordinates exhibit the same truncation, even though feature properties don’t.
geometry": {
o “type”: “Point”,
o “coordinates”: [
§ 139,
§ -19,
§ 212
· “geometry_name”: “geometry”,
· “properties”: {
o “eno”: 5757,
o “sampling_feature”: “DDH 83-1”,
o “sampling_feature_type”: “borehole”,
o “sampling_feature_subtype”: “petroleum - stratigraphic investigation”,
o “latitude_gda94”: -18.8601667,
o “longitude_gda94”: 138.6970111,
Sent: Tuesday, 2 November 2021 12:17 PM
To: Humphries, Graham Graham.Humphries@anonymised.com; ‘geoserver-users@lists.sourceforge.net’ geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] ‘Zero’ for Number of decimals (GML and GeoJSON output) in Global settings truncates CSV floats to ints [SEC=UNOFFICIAL]
Hi Graham
The problem is the setting has an inconsistent behaviour depending on output format
GML32 with number of decimal places 0:
<coit:latitude_gda94>
-18.8601667
</coit:latitude_gda94>
<coit:longitude_gda94>
138.6970111
</coit:longitude_gda94>
GeoJSON with number of decimal places 0:
CSV with number of decimal places 0:
latitude_gda94
longitude_gda94
-19
139
From: Humphries, Graham <Graham.Humphries@anonymised.com>
Sent: Tuesday, 2 November 2021 11:40 AM
To: Michael Sexton <Michael.Sexton@anonymised.com>; ‘geoserver-users@lists.sourceforge.net’ <geoserver-users@lists.sourceforge.net>
Subject: RE: ‘Zero’ for Number of decimals (GML and GeoJSON output) in Global settings truncates CSV floats to ints [SEC=UNOFFICIAL]
I would not think this is a bug. If there are zero decimal places how can any software reading the CSV know the number is meant to be a float?
This is a limitation of converting to a text file
From: Michael Sexton <Michael.Sexton@anonymised.com>
Sent: Tuesday, 2 November 2021 11:19 AM
To: ‘geoserver-users@lists.sourceforge.net’ <geoserver-users@lists.sourceforge.net>
Subject: [Geoserver-users] ‘Zero’ for Number of decimals (GML and GeoJSON output) in Global settings truncates CSV floats to ints [SEC=UNOFFICIAL]
Hi
This affects CSV output format for 2.19.2
The setting of ‘0’ in ‘Number of decimals (GML and GeoJSON output)’ for the Global settings, which for these output formats leaves the number of decimals unbounded, has the unfortunate result of truncating floats in CSV output to integers.
I have not checked if this affects other output formats. Is this bug already known or should I create a JIRA ticket?
Thanks
Michael Sexton
Data Analyst | MEGIS
Minerals Energy Groundwater | GEOSCIENCE AUSTRALIA
__________________________________________________****__________
Phone: +61 2 6249 9262 Fax: +61 2 6249 9999
Email: Michael.Sexton@anonymised.com Web: www.ga.gov.au
Cnr Jerrabomberra Avenue and Hindmarsh Drive Symonston ACT 2609
GPO Box 378 Canberra ACT 2601 Australia
Applying geoscience to Australia’s most important challenges
Geoscience Australia Disclaimer: This e-mail (and files transmitted with it) is intended only for the person or entity to which it is addressed. If you are not the intended recipient, then you have received this e-mail by mistake and any use, dissemination, forwarding, printing or copying of this e-mail and its file attachments is prohibited. The security of emails transmitted cannot be guaranteed; by forwarding or replying to this email, you acknowledge and accept these risks.
CONFIDENTIALITY NOTICE AND DISCLAIMER
The information in this transmission may be confidential and/or protected by legal professional privilege, and is intended only for the person or persons to whom it is addressed. If you are not such a person, you are warned that any disclosure, copying or dissemination of the information is unauthorised. If you have received the transmission in error, please immediately contact this office by telephone, fax or email, to inform us of the error and to enable arrangements to be made for the destruction of the transmission, or its return at our cost. No liability is accepted for any unauthorised use of the information contained in this transmission.
