[Geoserver-users] Zoom
After upgrading from 2.5.3 to 2.8.2, we experienced a significant decrease in performance when increasing the zoom level to the point of becoming unresponsive (zooming in tighter around the 0-4 zoom level).
The issue also occurred when using any Geoserver version 2.6.x and up and did not occur with any Geoserver version 2.5.x.
We are using floating point numbers for RasterSymbolizer for the colormap.
Has anyone else experienced this problem?
Matt
there should be some fixes for slowdowns caused by heavy raster oversampling in 2.8.4, try it out.
On Wed, Jul 6, 2016 at 5:35 PM, Mason, Matthew <MATTHEW.S.MASON@anonymised.com> wrote:
Matt
This communication (including any attachments) may contain information that is proprietary, confidential or exempt from disclosure. If you are not the intended recipient, please note that further dissemination, distribution, use or copying of this communication is strictly prohibited. Anyone who received this message in error should notify the sender immediately by telephone or by return email and delete it from his or her computer.
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hey Andrea,
I played around with 2.8.4 as well, but also noticed the same issue of the performance hit in terms of response time where upon zooming in to the max zoom level, the layers had difficulty rendering and couldn’t completely finish rendering.
I did notice though that in 2.8.4 the memory usage was much more constant and not approaching the max allocated which I believe was part of the problem with the prior versions of 2.6 and up and that seemed to help a bit, but didn’t solve it.
Thanks again,
Matt
On Wed, Jul 6, 2016 at 5:35 PM, Mason, Matthew <MATTHEW.S.MASON@…554…> wrote:
Matt
Ing. Andrea Aime
@geowolf
Technical Lead
I get that when I try to zoom out (not in) on a really crowded layer, but it has nothing to do with geoserver versions.
May I suggest you try a vanilla style on your layer and see if the issue continues?
It might be that something in the SLD is handled differently on your new geoserver version.
Also 2.9.0 and 2.8.4 are already out, you may want to try those in case you are upgrading to the latest version.
Best,
--Daniel
Em 06/07/2016 12:35, Mason, Matthew escreveu:
Matt
Hi Matthew,
the ticket I was referring to is this one: https://osgeo-org.atlassian.net/browse/GEOT-5391
The ticket links to https://osgeo-org.atlassian.net/browse/GEOS-7464 which was not closed,
Simone says there is still some work to do, but I do not have specifics on it.
You might want to comment on that ticket and attach a way to reproduce the slowdown (data, style, request)
On Wed, Jul 6, 2016 at 6:18 PM, Mason, Matthew <MATTHEW.S.MASON@anonymised.com> wrote:
Hey Andrea,
Thanks again,
Matt
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Wednesday, July 06, 2016 12:04 PM
To: Mason, Matthew
Subject: Re: [Geoserver-users] Zoom
Matt
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Oh, 2.6.0 is when we introduced the machinery to make rasters wrap the
dateline, handle poles
and other projection related issues. It's called "advanced projection
handling", you might want into
the WMS settings and try disabling it, see if that helps any
Ing. Andrea Aime
@geowolf
Technical Lead
I tested this and it seems like turning off the advanced projection handling helped increase the performance slightly, however, some of the requests still took way too long when zoomed in tightly resulting in timeout after 60 seconds.
I tested these settings in both 2.8.2 and 2.8.4.
I’m not sure if its relevant, but the area that I’m zooming in on isn’t near the dateline, poles, or the equator.
Matt
On Wed, Jul 6, 2016 at 6:18 PM, Mason, Matthew <MATTHEW.S.MASON@…554…> wrote:
Oh, 2.6.0 is when we introduced the machinery to make rasters wrap the dateline, handle poles
and other projection related issues. It’s called “advanced projection handling”, you might want into
Ing. Andrea Aime
@geowolf
Technical Lead
Dear Matt,
FYI https://osgeo-org.atlassian.net/browse/GEOS-7464 has been fixed on
master and now we are backporting to the other versions.
It would be great if you can grab a master nightly build and give it a
try to let us know how it goes.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Jul 7, 2016 at 4:43 PM, Mason, Matthew <MATTHEW.S.MASON@anonymised.com> wrote:
seconds.
Matt
Andrea Aime
Sent: Thursday, July 07, 2016 3:31 AM
To: Mason, Matthew
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
