I'm experiencing very weird problem with Geoserver. On my website I'm using Google Maps to display some petroleum data. One of the options that user is able to do is to display different layers on top of Google maps. Everything works fine until user zoom in for a few levels. At this stage Geoserver dramatically decrease speed of image rendering. To illustrate this these are approx. times required to display one layer on different zoom levels.
* zoom level 4- 8 sec
* zoom level 5- 7 sec
* zoom level 6- 10 sec
* zoom level 7- 30 sec
* zoom level 8- 42 sec
* zoom level 9- 50 sec
* zoom level 10- 1 min 1 sec
* zoom level 11- >2min at this stage Geoserver (or Jetty) brakes
down and I have to restart it. I also realized that Java taking
90% of my cpu usage on low zoom levels.
Firstly I thought that this is the case because of the old hardware that I used, but problem remains the same even after I bought the brand new Dell server with plenty of memory space and processing speed. I'm pretty sure that this problem is not related to Google Maps (but I maybe wrong) because, browser waits for geoserver not for google server.
I also tried to deploy geoserver on Tomcat without much success (on tomcat is even worse, because tomcat crash after zoom level 9).
I am not sure what causing this problem, especially when at this stage only one user uses this web application. So any ideas on how I should approach this problem will be greatly,greatly appreciated.
(The layer is created from shapefile(2mb))
Thanking in advance,
Sasha
P.S. These are messages that I'm getting from Geoserver.
WARN!! Exception for /geoserver/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=topp:equal-500NorthEast&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=142.03125,-27.059125784374054,143.4375,-25.79989118208832&WIDTH=256&HEIGHT=256&reaspect=false
java.lang.IllegalStateException
at org.mortbay.jetty.servlet.ServletHttpResponse.getWriter(ServletHttpResponse.java:540)
at org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:729)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:788)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:769)
EVENT LOW ON THREADS ((50-47+0)<5) on SocketListener@anonymised.com:8080
WARN!! OUT OF THREADS: SocketListener@anonymised.com:8080
WARN!! No thread for Socket[addr=/10.0.0.186,port=2221,localport=8080]
Very odd. What version of geoserver are you using? And are you using indexed shapefile as the datastore or regular? Indexed may help some, but it still shouldn't be that dramatic of an increase. The low on threads and out of threads messages are odd.
And you're using the wms-gs javascript from the geoserver docs to display on google maps, yes?
Chris
Sasha wrote:
Sasha
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
When you measure these times you let all processes finish before clicking on zoom again? I mean, you could be accumulating processes from zoom to zoom and things start getting slow. And I dont know how efficient is the access to the shapefile from geoserver. In the case of PostGIS my application accumulates processes in the server while the user moves around with Google Maps (the user request faster than the server finish serving). In my case then things stabilize and I dont get to a crash like you... but maybe with shapefiles is different..
Just a suggestion.
Javier.
On 06/09/2006, at 4:27, Sasha wrote:
Sasha
at
at
at
at
<<When you measure these times you let all processes finish before clicking on zoom again?>>
Yep.
I've found that problem has been caused by only a few shapefiles, not all of them (nothing to do with size of a file, because the largest shapefile works fine).
I will probably convert these files into PostGIS database soon to see what will happend.
Anyway thanks for help.
Sasha
Javier de la Torre wrote:
Hi Sasha,
Maybe just a stupid question, but...
Just a suggestion.
Javier.
Sasha
at
at
at
at
