[Geoserver-users] ZoomTo / Bounding Box Question -- Oracle
List …
Before my question I need to compliment the Geoserver team on the speed improvements that has been implemented for Oracle. I am using 1.6-Beta 3 at the moment.
My question related to integration with Orcale and VE, Google Mashups:
I have mashups to VE etc working from Oracle data …
The geoserver map is using epsg:900913.
The data sources are in different projections : e.g. 4236 , 81948 etc.
The functionality that I am prototyping finds objects from the database/data sources through a non-spatial query , which when selected then zooms the map to the object’s bounding box.
The question that I have is how do I get the bounding box/envelope for a specific entity in a specified projection - in this case 900913 - to use to drive openlayers.Zoomto functionality ?
WFS’s getFeature gives the objects envelope in the source SRS …
Any suggestions will be appreciated.
Thanks
Pierre le Roux
p. 256 604.0122
e. zpleroux@anonymised.com
There may be other ways to do it, but one way would be to do a WFS 1.1 GetFeature call. It can do reprojection, so I think if you request it in 900913 then you'll get the envelope back in that projection. You can also set a param, I think it's called resultType or something, to 'hits', and that just returns the number of features that would match the call and I believe also returns the envelope. I could be wrong about some of these, but it's probably worth checking out.
Chris
Pierre le Roux wrote:
List ...
I have mashups to VE etc working from Oracle data ...
The functionality that I am prototyping finds objects from the database/data sources through a non-spatial query , which when selected then zooms the map to the object's bounding box.
WFS's getFeature gives the objects envelope in the source SRS ...
Thanks
Pierre le Roux
p. 256 604.0122
e. zpleroux@anonymised.com <mailto:zpleroux@anonymised.com>
!DSPAM:4005,4703d517180881030819293!
Geoserver-users mailing list
Thanks Chris …
Will give that a whirl.
Pierre
in 900913 then you’ll get the envelope back in that projection. You can
also set a param, I think it’s called resultType or something, to
‘hits’, and that just returns the number of features that would match
about some of these, but it’s probably worth checking out.
Chris
List …
at the moment.
Thanks
Pierre le Roux
p. 256 604.0122
e. zpleroux@anonymised.com mailto:[zpleroux@anonymised.com](mailto:zpleroux@anonymised.com)
Pierre le Roux
p. 256 604.0122
Chris …
Seems like your suggestion did the trick !
This is the request:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&typename=topp:states&maxFeatures=1&SRSNAME=EPSG:900913
Thanks
Pierre
On 10/3/07, Pierre le Roux <zpleroux@anonymised.com> wrote:
Thanks Chris …
Pierre
Chris
List …
at the moment.
Thanks
Pierre le Roux
p. 256 604.0122
e. zpleroux@anonymised.com <mailto: zpleroux@anonymised.com>
Pierre le Roux
p. 256 604.0122
Pierre le Roux
p. 256 604.0122
Wow, this is some neat out of the box thinking.
Anyways, may I chime in and observer this would be an easy job for a
RESTful WPS service to implement? :slight_smile:
