GeoTools / GeoServer PMC meeting - 2024-11-19
Attending
- Peter Smythe
- Kevin Smith
- Andrea Aime
- Jody Garnett
- Jukka Rahkkonen
Actions from prior meetings:
- Jody: Done: Create landing page with FAQ for GS3
- Jody: Done: Draft some slides for OSGeo AGM and share for review
- All: Share the GeoServer 3 call for crowdfunding around, talk to coworkers, boss, etc.
Agenda
- FOSS4G Belem incoming
- OSGEO slides
- OGC API Features status update
- CSP GSIP
- Modules cleanup
- Ask for money ala QGIS
- Chit chat
Actions
- Jody: GeoTools AGM Page
- Jody: Copy 2024 sponsorship opportunities, removing CITE testing as a goal (done)
- Andrea: Ask GitHub about hosting downloads and any size / bandwidth limits (done)
- Andrea: Send modules cleanup list to the geoserver devel forum (not email) (done)
Jody and Gabriel are going to represent GeoServer
- GeoServer workshop, state of presentation, ogcapi-features presentation, GeoServer cloud, rendering overture without local storage, K8S operator for GeoServer
- Security with Kindness and Compassion
- GeoTools, JTS and Friends
OSGEO slides
- GeoTools slide - action item? Jody to make something…
- GeoServer slide / GeoServer 3 slide
- sidebar:
Progress with Gabe and Andrea:
Success
- Pass QA fully!
- Pass CITE tests, Gabe created github actions to run CITE tests!
- Found some bugs in the CITE tests themselves and made PRs
- PRs now run CITE tests! Amazing
- Andrea working on WMS 1.3, close to pass as well
- Machinery in place to try out more tests
- Q: Can we kill the Jenkins jobs for building CITE images?
Check with Gabe first.
- Build geoserver.war, stick in docker image, pull TEAM Engine images from docker hub and then run the tests, then report the results
In progress:
- Proposal to graduate the CQL2 modules in geotools-devel, please vote (implemented the abstract test suite (ATS) against GeoPackage, pretty extensive, thanks OGC)
- discussion about case insensitive compare and sort / temporal / and so on that not implemented yet
- Thanks to Pierre Mauduit for working on the CQL2 ATS implementation
- GSIP-230 - OGCAPI Features Extension (draft)
- Gabe has deadline on this, so please vote when it comes up for review
- Jody slow to make conformance enable/disable (working on user interface now)
- Ability to turn off functionality, like sortBy which may change in the future
CSP GSIP
GSIP-227 - Content-Security-Policy Headers
- proposal is a bit more about communicating a decision sort of already made
- Steve has been asking for review on the PRs
Modules cleanup
See geoserver-devel for unused / unloved/ unsupported modules (often don’t build):
- app-schema/webservice-test: run only with custom profiles (oddly, both “webservice" and "app-schema” do). It does not even start to build, depends on the gone gt-webservice-test module.
- gwc-distributed: containing just a Spring context and some dependencies, enables the Hazelcast distributed in memory tile cache. Anyone using it?
- imagemap, enables the HTML image map output format. I guess nobody today uses HTML image maps in cartography, but if you do, please let me know.
- jdbc-metrics seems to collect statistics about queries in JDBCFeatureReader. On one side, it seems like a useful tool to track time actually spent talking to the database, on the other, it has no documentation has has seen to action for the past 7 years. Anyone using it, or that would be interested in writing a bit of documentation for it?
- monitor-hibernate provides database storage for the monitoring subsystem. Unmaintained, based on the dead Google code genericdao framework, and afflicted by using primary keys in a log table (insertions become slower and slower), it probably deserves some final rest, a suitable replacement would be a rewrite, not a few small fixes.
- pgraster despite the name it’s an easy to use UI on top of the no longer existing gt-imagemosaicjdbc. This one already has a removal PR.
- saml is gone already, but its assembly descriptor survived and should also be removed.
- wps-sextante is based on the Sextante java libraries… which I cannot find any more. The version it depends onto has been released around 2012, the module received its last direct commit in 2015 (all others are mass refactors), has no documentation, Sextante for Java seems nowhere to be found…
- xslt is a WFS output format generator based on XSLT that was demoted to community in May 2023. Looks like nobody complained, I’d complete the job.
Regarding extensions, the following look like good candidates for demotion to community:
- h2 store, based on the old and unmaintained H2 v1.x. While we cannot get rid of it completely, as some modules keep on depending on it (e.g. the NetCDF store family), I’d make its availability as a vector store harder to get.
Action:
- Andrea send modules cleanup list to the geoserver devel forum (not email) (done)
Peter liked the QGIS download + donate reminder:
Can we implement the same? Donate via OSGeo or GitHub
See https://geoserver.org/sponsor page for Donating via PayPal or GitHub
Quick: Add a note to the download for “latest” releases by updating the template
Possibly best coupled with uploading the artifacts to the GitHub tag?
- to avoid poor experience of waiting on geosever.org and then waiting on SF ads
Will we have issues with uploading lots of large binaries in GitHub? Is there a limit?
- about releases …
Each file included in a release must be under 2 GiB. There is no limit on the total size of a release, nor bandwidth usage. - Can trial addings some steps to release script alongside SF
- alternative: repo.osgeo.org - can create a “raw” repository for downloads
OSGeo Budget request:
- Need a wiki page with sponsorship opportunities and budget request for 2025
- action: Copy 2024 sponsorship opportunities, removing CITE testing as a goal
- We should respond before next meeting?
- Do we wish to use our 2024 budget for anything…-
Chit chat
Crowdfunding
- page now available: GeoServer 3 Crowdfunding
- Some glitch with sponsor logo, was case sensitive (fixed)
Release update:
Peter working on blog post
small hiccup with geotools release (strange maven dependency / assembly interaction) thanks for fixing Jody
small hiccup with windows installer (credentials updated) thanks for fixing Jaun
Info about OGC Certifications How Our Compliance Program Works - Open Geospatial Consortium
- OGC Certification Services - OSGeo
- This would be an excellent use of our 2024 budget (and we have contributions from prior sponsors)
- Andrea provides a demo (main CITE engine offline, but beta one is working)
- Keep in mind:
- Looks like OSGeo offers hosting (a VM with Docker)
- So we would need some docker images to run on different ports
- The data folder has the sample data for each test
- WFS test is destructive (makes changes) and needs a reset to clean state
- Recommendation: Make a demo request to remove all contents, and then insert the data again
- WCS 1.0 version negotiation does not work; so needs a cut down war
