just a note as the situation is a bit messy. Language support in GeoServer
has been
added to support INSPIRE, with a secondary goal of making it generally
available even without the INSPIRE plugin.
The LANGUAGE parameter is an INSPIRE specific parameter, it’s not part of
the OGC specifications.
If you look at specification like WMS 1.3 or SLD (that’s where
GetLegendGraphic comes from) there is
no mention of language support whatsoever.
Those specs are old enough that they are not really referencing any “Web
Services Common” base,
but even taking the latest WSC specification, 2.0 (dated back 2010) there
is only mention of a
“acceptlanguages” parameter, designed specifically for the GetCapabilities
(reminder, of all OGC protocols,
only WCS 2.0 is based on WSC 2.0).
In the regulatory void, I have the impression the current implementation
looks up “LANGUAGES” in GetMap/GetLegendGraphics,
and ACCEPTLANGUAGES only in GetCapabilities, and tries to use them as ISO
codes.
The INSPIRE plugin adds a translation layer, looks into LANGUAGES for 3
letter codes and
retrofits them into ISO codes
https://github.com/geoserver/geoserver/blob/62453b2267ea4f9a05775a54da128d93be1626ae/src/extension/inspire/src/main/java/org/geoserver/inspire/LanguagesDispatcherCallback.java#L13
before
the request parsers can look at them.
More work is likely needed to get a consistent behavior outside of the
INSPIRE scenario, for those
interested in getting it done, see the usual guide:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail
On Wed, Sep 18, 2024 at 4:31 PM Cécile Vuilleumier via OSGeo Discourse <
noreply@discourse.osgeo.org> wrote:
vuilleumierc https://discourse.osgeo.org/u/vuilleumierc
September 18
Possibly linked to this [GEOS-11249] - JIRA
https://osgeo-org.atlassian.net/browse/GEOS-11249?
For us it works now with 2.25. My understanding is that the language
parameter should be language=eng if you have the INSPIRE extension. If
not, it should be en.
So with this in the SLD:
<Title>
Default label<Localized lang="en">English</Localized>
<Localized lang="de">Deutsch</Localized>
<Localized lang="fr">Français</Localized>
<Localized lang="it">Italiano</Localized>
</Title>
And language=en (without INSPIRE) or language=eng (with INSPIRE) in the
request, it should work in 2.25
Visit Topic
https://discourse.osgeo.org/t/getlegendgraphic-i18n-after-2-22-2/50926/5
or reply to this email to respond.
To unsubscribe from these emails, click here
https://discourse.osgeo.org/email/unsubscribe/7e2109b419f2dad4d8ade95de3e61e3d0111072f6fee000b4e35e96be6de0e5f
