Folks,
I realize that this is not exactly the forum for asking this kind of question
but since I have seen several references to LINUX here, I will ask you.
I would like to run LINUX on my 485-25. I downloaded the linux-0.99.6.tar file
from somewhere (I can't remember where). It is obvious that this version
is intended to be installed in a system already running UNIX or LINUX. How
do I get started? Is there a small bootable LINUX that can be installed,
with tools like make and sed in place. I already installed gcc 2.2.2 in the
pc and it seems to work OK. I though that I could build LINUX using this
gcc but without GNU Make etc I an still stuck.
I am an experienced UNIX/GNU person and have installed GNU stuff many times.
Once I get off the ground, I will be fine.
Doug Dotson
ddotson@scada_2.tate.com
ps. I ultimately want to run GRASS on this PC under LINUX.
