I’m using the gorgeous Atlante with Qgis 2.4. I’ve a polygon layer that command atlante and one other point layer in 1-1 relation with the firs one (using the PK_id field) that has a rule legend where:
if $atlasfeatureid = $id use a simbol
else use another simbol.
Using this I can move from different layout (with defined zoom) and highlight my point object.
However I have some problem to maintain the right connection from the 2 layer 'cause the $atlasfeatureid variable contain the current row number,so it works fine only if the two table have the same order.
I read in [0] that Natan is thinking to of adding a $altasfeature and then a getattr($altasfeature, ‘field’) in order to acces to the table attribute (and im my case to the FK_id).
Anyone know if this function yet implemented? And if it’s “Yes” how can I use it to solve my problem.
Thank in advance
Luca
[0] http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
