Ti riporto due esempi che uso io, per poligoni o linestring.
CREATE TABLE layerpoligonale_clippato(
lpoly_id TEXT,
lpoly_att1 TEXT,
lpoly_att2 TEXT,
lpoly_att3 TEXT,
lpoly_att4 TEXT);
select addgeometrycolumn('layerpoligonale_clippato', 'geom', 25832,
'MULTIPOLYGON');
.timer ON
insert into layerpoligonale_clippato(
lpoly_id,
lpoly_att1,
lpoly_att2,
lpoly_att3,
lpoly_att4, geom)
select
a.lpoly_id,
a.lpoly_att1,
a.lpoly_att2,
a.lpoly_att3,
a.lpoly_att4,
CastToMulti(SanitizeGeometry(ST_SnapToGrid(ST_CollectionExtract(CastToGeometryCollection(ST_Intersection(a.geom,ww.geomclip)),3),
0.0, 0.0, 0.01, 0.01)))
from layerpoligonaleoriginale as a, layer_geometriadiclip as ww
where ((ST_Intersects(a.geom, ww.geomclip)=1)
AND ww.ROWID IN (
SELECT ROWID FROM SpatialIndex
WHERE f_table_name='layer_geometriadiclip' AND search_frame=a.geom));
.timer OFF
update layerpoligonale_clippato set geom = st_makevalid(geom) where
st_isvalid(geom) = 0;
select * from layerpoligonale_clippato where geom is null;
delete from layerpoligonale_clippato where geom is null;
.dumpshp layerpoligonale_clippato geom layerpoligonale_clippato CP1252
CREATE TABLE layerlineare_clippato(
lline_id TEXT,
lline_att1 TEXT,
lline_att2 TEXT,
lline_att3 TEXT,
lline_att4 TEXT);
select addgeometrycolumn('layerlineare_clippato', 'geom', 25832,
'MULTILINESTRING');
.timer ON
insert into layerlineare_clippato(
lline_id,
lline_att1,
lline_att2,
lline_att3,
lline_att4, geom)
select
a.lline_id,
a.lline_att1,
a.lline_att2,
a.lline_att3,
a.lline_att4,
CastToMulti(SanitizeGeometry(ST_SnapToGrid(ST_CollectionExtract(CastToGeometryCollection(ST_Intersection(a.geom,ww.geomclip)),2),
from layerlineare_originale as a, layer_geometriadiclip as ww
AND ww.ROWID IN (
.timer OFF
update layerlineare_clippato set geom = st_makevalid(geom) where
select * from layerlineare_clippato where geom is null;
delete from layerlineare_clippato where geom is null;
.dumpshp layerlineare_clippato geom layerlineare_clippato CP1252
Dentro, per mi esigenze, trovi anche un arrotondamento delle
coordinate al centimetro, alcune ripuliture delle geometrie (sanitize
e poi makevalid, e l'eliminazione di eventuali geometrie nulle), e
soprattutto trovi come usare gli spatial index (indispensabili su
tabelle con molte geometrie).
Considera che un campo geometria va effettivamente dichiarato ed aggiunto
Nella tua query tu selezioni tutte le LINES che intersecano la
EXTENSION.GEOM, ma non effettui alcun taglio (la st_intersects
verifica che vi sia una intersezione, non la esegue: per intersecare
la funzione è st_intersection).
Prova a ragionare sui due sample che ti ho proposto, cercando tutti i
comandi usati in
http://www.gaia-gis.it/gaia-sins/spatialite-sql-4.2.0.html
e prova anche qualche esempio che trovi nel cookbook in
https://www.gaia-gis.it/fossil/libspatialite/wiki?name=misc-docs
E' importante lo studio del SQL spaziale (Spatialite o Postgis) perchè
insegna ad affrontare le questioni geografiche con la necessaria
consapevolezza e non, come di solito succede con i GIS desktop, in
maniera empirica e senza una completa comprensione di ciò che succede
dietro le quinte!
Ciao,
Maurizio
Il 05/01/15, matteo<matteo.ghetta@gmail.com> ha scritto:
Ciao a tutti,
ho un problema (sono alle prime armi, abbiate pietà..) con spatialite.
Molto in breve, ho due layer un DB di tutta l'italia e un layer su cui
vorrei clippare l'italia.
Ora, la query che ho lanciato è:
create table clipped_lines as
select * from lines, estensione
where st_intersects(lines.GEOMETRY, extension.geom)
dove *lines* sono le polilinee dell'italia e estensione è il layer di clip.
La clip viene effettivamente fatta, ma il risultato è una tabella e non
un layer spaziale che posso aggiungere alla mappa.
Qualche esperto sa darmi una mano?
Grazie mille
Matteo
Gfoss@lists.gfoss.it
I messaggi di questa lista non hanno relazione diretta con le posizioni
dell'Associazione GFOSS.it.
666+40 iscritti al 5.6.2014
