[Gfoss] cos'e' il software libero?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Per chi capisce l'americano, questo mi pare veramente esemplare:
http://www.youtube.com/watch?v=uJi2rkHiNqg
chiaro, semplice.
pc
Paolo Cavallini
http://www.faunalia.it/pc
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGE/s8/NedwLUzIr4RAp0FAJ989rmEPR8V/m2MiKdmOt9UcDNaswCgi4VQ
cee7U3Cx3XceN+6ZIvMRz28=
=029o
-----END PGP SIGNATURE-----
Ciao a tutti,
segnalo due posizioni aperte al JRC di Ispra (http://ec.europa.eu/dgs/jrc/index.cfm?id=1440).
La prima e' per uno sviluppatore GIS con conoscenze DBMS e web GIS, in ambito OpenSource (PostgreSQL/PostGIS e UMN MapServer).
La seconda richiede esperienza in Land use/Land cover (CORINE in particolare). Purtroppo il sw da utilizzare nel progetto รจ ArcGIS desktop, ma in tempi di crisi mi permetto di fare una segnalazione che utilizzi sw commerciali...
Per entrambe le posizioni potete trovare maggiori informazioni qui sotto e contattare Roberto Boca (393 9295121; roberto.boca@ext.jrc.it).
In bocca al lupo e buon fine settimana,
Diego
POSIZIONE 1
Profile:
1. Knowledge of design of Spatial Databases 2. Knowledge of open source DB (probably PostGres or PostGIS -- consultant will make that choice) 3. Knowledge of Map Server development (ideally University of MN as they want to stay Open Source)
Context:
The project is in collaboration with DG-AIDCO. They find many projects around the world. At the moment, all the information for each of these projects is stored in EXCEL !!! They want a web based system to interact with these data. I do not have an example of the data, but it contains information about the projects (amount of funding, duration, location, etc.). This is ideally suited for a GIS solution. On the backend the consultant will have to design a database and import the EXCEL data. On the front end, they would like a map to interact with the data but also the ability to interrogate the database through a form and display the results. Fairly straightforward.
The duration will initially be 8 months. This project is done through an administrative arrangement which will continue, and it is the intention for the work to continue beyond the initial eight months (at least for 1 year total). Personally, I think it will go longer than that.
Profile is SAP - NORMAL (not Specific mainly due to budget reasons). English is not enormously important, but it would be good to find someone with reasonable English.
They would like to launch the request ASAP with the idea of starting late June or early July.
POSIZIONE 2
Profilo richiesto:
- Esperto ArcGis Desktop e sue estensioni e possibilmente di "Model Builder"
- Esperienza in Land use/Land cover (progetto CORINE in particolare)
- Conoscenza di Access, Excel
- Possibilemente esperto di landscape ecology, analisi di indicatori, geo analysis. La laurea preferenziale, ma non assolutamente necessaria, potrebe essere Scienze ambientali/naturali e simili.
PhD. Ing. Diego Magni
diegomagni@yahoo.it
On Fri, May 1, 2009 at 10:18 AM, Diego Magni <diegomagni@yahoo.it> wrote:
Ciao a tutti,
Aggiungo il link diretto a tutte le altre posizioni aperte al JRC:
http://ec.europa.eu/dgs/jrc/index.cfm?id=3720
Guardate sotto IES e IPSC che sono i due instituti del sito di Ispra
con attivita' legate ai GIS. Non lasciatevi scoraggiare dai requisiti
richiesti ed esperienza ESRI&Co. Apprezzeranno molto le vostre
conoscense GFOSS e in generale le alternative open souce.
C
