[Gfoss] Degree
Qualcuno ha un po' di esperienza con questo framework?
http://deegree.sourceforge.net
Implementa diversi standard OGC non da poco
Web Map Service (WMS)
Web-based creation of maps out of raster and vector datasets. The generated maps can be visualized by common web browsers.
Web Feature Service (WFS)
Web-based access to vector geo-data, that is delivered as GML 2.1.1 conformant XML-documents to clients, which can the further process this data (for example in a desktop GIS).
Web Coverage Service (WCS)
Web-based access to raster geo-data, that can be delivered in several image formats (e.g. TIFF, GIF, JPEG,BMP, PNM) and can then further be processed.
Web Catalog Service (WCAS)
based on OGC Web Services Stateless Catalog Profile.
Web-based catalog service for administration and querying of metadata describing geo-data and geo-services. A catalog service allows retrieval of data and services based on spatial and textual search criteria.
Web Gazetteer Service (WFS-G)
Service allowing geo-referencing of geographic entities based on textual identifiers (e.g. place names)
Web Terrain Service (WTS)
Creation of views out of 3D-data like city models and digital elevation models. The generated views can be visualized by standard web browsers.
Web Coordinate Transformation Service (WCTS)
A WCTS allows the web-based transformation of geographic coordinates from one coordinate references system into another.
Putroppo non ho ancora avuto modo/tempo di provarlo (ricordo che sto "giocando" con il voto elettronico).
Sembra molto interessante (tra l'altro sono incuriosito da WTS).
... per la gioia di Paolo e' in java ...
Maurizio Napolitano
ITC-irst
Povo(TN) - Italy
tel +39 0461 314341
http://www.linux.it/~napo
Il giorno mer, 14/06/2006 alle 09.11 +0200, Maurizio Napolitano ha
scritto:
Con tutte 'ste applicazioni in Java le cose sono due: o la Sun libera
quanto prima il codice, oppure PostGIS insegna la via maestra del
porting...
Steko il non-programmatore...
Stefano Costa
http://www.iosa.it Software Open Source per l'Archeologia
Jabber: steko@jabber.linux.it
GnuPG Key ID 1024D/0xD0D30245
Linux Registered User #385969 counter.li.org
porting...
... c'e' anche la terza: usare gcj
http://gcc.gnu.org/java/
Esperianza diretta non ancora, ma lo stiamo installando ed evaluando. Sono
però stato alla
conferenza deegree day 2006 a Bonn la settimana scorsa, e devo dire che mi
hanno fatto un
ottima impressione per la loro professionalità e per la qualità dei
speakers.
Una cosa non da poco: Il WMS e WCS di deegree sono l’implementazione di
riferimento
dell’OGC. Quindi a maggior ragione ci si può aspettare che siano completi
e funzionanti
(sulle performance dobbiamo ancora fare dei test).
E che sia Java: per architetture web complesse non vedo molte
alternative a J2EE e .NET
(e preferisco di gran lunga Java). L’interfaccia web personalizzata poi la
fai in che linguaggio
ti pare.
Seguiranno aggiornamenti…
On 14 Jun 2006 at 9:11, Maurizio Napolitano wrote:
Qualcuno ha un po’ di esperienza con questo framework?
processed.
“giocando” con il voto elettronico).
Sembra molto interessante (tra l’altro sono incuriosito da WTS).
… per la gioia di Paolo e’ in java …
Maurizio Napolitano
ITC-irst
Povo(TN) - Italy
tel +39 0461 314341
Gfoss mailing list
Gfoss@faunalia.com
http://www.faunalia.com/cgi-bin/mailman/listinfo/gfoss
