ma che è Rosa?
bingo, usano:
ECW JPEG 2000 plug-in is currently not available for this platform
Welcome to our web site. In order to improve your interactive experience, we make extensive use of the Image Web Server <http://www.earthetc.com/> to provide access to very large images over the Internet.
Your browser does not appear to support the ECW JPEG 2000 plug-in <http://www.ermapper.com/products/ecw/ecw.pdf> needed to view these images. The following platforms are currently supported:
*Windows 98/NT4/2000/XP, with:*
* Internet Explorer 4.01 SP2 or higher
* Netscape 7.0 or higher
* Mozilla 1.4 or higher
* Firefox 1.0 or higher
* Sun Java Plugin 1.4.2 or higher (for Java support on all of the
above browsers)
*Mac OS X (10.3 Panther) with:*
* Safari 1.2.4 using Java 1.4 or above
*Linux/Solaris (Java 1.4 or above is required) with:*
If your platform is not listed above, but supports a Java environment that is JavaScript enabled (sometimes called "LiveConnect"), you may be able to use the Java client. In this case, contact the site administrator for more information. Support for other platforms is being added all the time, so please check back again soon.
Thank you
Image Web Server Support
©1999-2005 Earth Resource Mapping <http://www.ermapper.com>
