[Gfoss] Error returned installing QGIS 2.12
Hello all,
an user tells me that he had an error installing QGIS 2.12 64 bit on Windows 7.
This is the capture screeen during error:
https://drive.google.com/file/d/0By5p_WoL_LoFRlUzVDNtcWEwTlk/view?usp=sharing
He has oracle client installed. Perhaps, it cannot rewrite the oracle dll ?
Somebody other had and solved this error ? And in case how ?
That because after the error, the install terminates unsuccesfully :frowning:
Thank you in advance for any info about this
A presto
Roberto
I can’t confirm the error.
I managed last week to install QGIS 2.12 64-bit on a Windows 7 64-bit with two Oracle Client already installed.
The Oracle file form QGIS setup didn’t overwrite the existing files nor I had any error.
All the best
Stefano
2015-11-04 15:51 GMT+01:00 Geo DrinX <geodrinx@gmail.com>:
Hello all,
A presto
Roberto
Gfoss@lists.gfoss.it
786 iscritti al 30.9.2015
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2015-11-04 15:54 GMT+01:00 Stefano Iacovella <stefano.iacovella@gmail.com>:
I can't confirm the error.
The Oracle file form QGIS setup didn't overwrite the existing files nor I
had any error.
Well, so what do you advise me to do, for not having the message that
appears in the immage ?
Thank you
Roberto
Ciao Roberto,
Rispondo in Italiano perché tanto la lista di sviluppo rigetta i miei messaggi. Onestamente io non ho eseguito alcun configurazione particolare.
I due client Oracle, 32-bit e 64-bit, li avevo installati precedentemente.
Ho usato l’installer standalone di QGIS 2.12 a 64-bit.
Tu in che path hai il client Oracle e in quale installi QGIS?
Stefano
Well, so what do you advise me to do, for not having the message that appears in the immage ?
Thank you
Roberto
