Ciao Marco,
On Jan 23, 2008 10:55 AM, <marco.pasetti@alice.it> wrote:
Avrei solo altre 2 domande:
1. rispetto alle note che mi hai indicato, nel log ho (in più) i seguenti
errori:
/usr/local/src/grass-6.3.0RC4/imagery/i.ortho.photo/photo.rectify
... fallisce per questi segnali SIG_* assenti su MinW (mi pare)
Poin non ci sono X-Monitors per MingW che sono richiesti da questi i.*
commandi.
/usr/local/src/grass-6.3.0RC4/raster/r.li/r.li.daemon
/usr/local/src/grass-6.3.0RC4/raster/r.li/r.li.edgedensity
... falliscono perchè r.li.daemon fallisce ...
Avevi controllato l'archivio di GRASS?
Paul Kelly:
"Main problems as far as I can see:
- Use of FIFOs? AIUI Windows doesn't have FIFOs so that won't work.
- Also I don't think fork() is available on Windows either
Brad Douglas:
"Linux: fork() exec()
Win32: CreateProcess()
Linux: exit()
Win32: ExitProcess()
Linux: get/putenv()
Win32: Get/SetEnvironmentVariable()
Linux: waitpid()
Win32: GetExitCodeProcess()
Linux; getpid()
Win32: GetCurrentProcessId()
It would be nice to have wrappers for these functions. Thoughts, Glynn?
Glynn Clements (Jan 05, 2007):
"There are limits to "wrapping" process management. It isn't as if Unix
and Windows are the same except for the names given to the functions;
the semantics are quite different. Particularly the Unix model of
separate fork() and exec(), with the ability to substantially alter
the state of the child between the two, versus a single
CreateProcess() call with a fixed set of parameters.
Having said that, you could wrap the simpler cases. You would need to
stick to what's available on Windows; some of the more complex things
which can be done on Unix either aren't possible on Windows (e.g.
setting descriptors other than stdin/stdout/stderr) or don't have any
equivalent there (e.g. signal handling).
I already started writing potential replacements for typical usage of
system(); see lib/gis/spawn.c. G_spawn() is a direct replacement for
the simplest uses of system(), except that it accepts individual
arguments rather than a single string and doesn't use "sh -c ...".
G_spawn_ex() is intended to handle more advanced usage, e.g.
redirection, signal handling, environment variable substitution and
binding.
/usr/local/src/grass-6.3.0RC4/visualization/nviz
2. dici che sia meglio provare a compilare la RC03, magari mi da meno
errori? (magari adesso di provo direttamente, ma ci vogliono più di 2
ore!!!)
No, meglio RC4! Per favore dimmi cosa non va più in RC4.
In generale propogo di discutere questi dettagli tecnici nella GRASS
developers list dove ci sono tanti esperti di MingW...:
ciao
