[Gfoss] errore datum...
salve,
sto creando una LOCATION tramite il codice EPSG (23033), relativo alla
proiezione ED50 / UTM 33N.
ma una volta scelto il codice, mi da il seguente errore:
g.proj returned the followind informational message: WARNING: Datum
<unknown> not recognised by GRASS and no parameters found.
secondo voi qualcosa non va nel file /usr/share/proj/epsg??
ciao,
Alfredo
2008/5/30 Alfredo Alessandrini <alfreale74@gmail.com>:
salve,
Stiamo investigando... sono in grado di replicare il problema.
Dovrebbe usare "European_Datum_1950" ma per qualche motivo
fallisce con EPSG 23033.
Il problema del datum riconoscimento in GRASS รจ stato risolto.
Di sotto la comunicazione di Paul Kelly (fix in
  http://trac.osgeo.org/grass/changeset/31652
ciao
On Sat, Jun 7, 2008 at 3:26 PM, Paul Kelly
<paul-grass@stjohnspoint.co.uk> wrote:
On Fri, 30 May 2008, Markus Neteler wrote:
Hello Paul,
a problem came up in the Italian list:
g.proj -c epsg=23033 loc=llll
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Location llll created!
This is now fixed in SVN trunk. It seems at some stage there were some
changes to the way GDAL parsed PROJ.4 strings such as "+init=epsg:XXXX" - as
far as I can see it now attempts to expand the string into a full PROJ.4
string before doing a secondary conversion to a WKT-format co-ordinate
system, and in the process the datum information is lost. I'm not sure what
the logic for this change is, but anyway I've worked around it by changing
g.proj to call OSRImportfromEPSG() directly when given the epsg= option.
However a consequence of this is that the old-style
g.proj -c proj4=init=epsg:XXXX location=newloc
will no longer work properly; you must use
g.proj -c epsg=XXXX location=newloc.
Many thanks to Alfredo Alessandrini for the original bug report. If there
are no issues I'll backport it to 6.4 later.
Paul
2008/5/30 Markus Neteler <neteler@osgeo.org>:
salve,
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
