[Gfoss] Errore raster con qgis2leaf 0.95 su OS
Ciao,
Cercando di esportare un progetto contenente un raster (jpg EPSG: 4326) da QGIS 2.2 su Mac OS X 10.9.3 mediante il plugin qgis2leaf versione: 0.95
ottengo l’errore sottostante, sapete dirmi come risolverlo o a chi rivolgermi ?
GRAZIE
An error has occured while executing Python code:
File “/Users/lucamoiana/.qgis2/python/plugins/qgis2leaf/qgis2leafdialog.py”, line 109, in export2leaf
qgis2leaf_exec(self.outFileName, self.basemapName, self.width, self.height, self.extent, self.full_screen, self.layer_list, self.visible, self.opacity)
File “/Users/lucamoiana/.qgis2/python/plugins/qgis2leaf/qgis2leaf_exec.py”, line 411, in qgis2leaf_exec
ret = subprocess.check_call([‘gdal_translate -of jpeg -outsize 100% 100% -a_srs EPSG:4326 ’ + filename_raster + " " + out_raster_name], shell=True)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 542, in check_call
raise CalledProcessError(retcode, cmd)
CalledProcessError: Command ‘[u’gdal_translate -of jpeg -outsize 100% 100% -a_srs EPSG:4326 /Users/lucamoiana/Documents/GIS/Paolo/DATI/cellatica_rprj.tif /Users/lucamoiana/Documents/GIS/Paolo/openlayers/export_2014_06_27_04_30_17/data/exp_cellaticarprj.jpg’]’ returned non-zero exit status 127
Python version:
2.7.5 (default, Mar 9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
QGIS version:
2.2.0-Valmiera Valmiera,
Python path: [‘/Users/lucamoiana/.qgis2/python/plugins/processing’, ‘/Users/lucamoiana/.qgis2/python/plugins/LecoS’, ‘/Users/lucamoiana/.qgis2/python/plugins/GeoCoding’, ‘/Applications/QGIS.app/Contents/MacOS/…/Resources/python’, u’/Users/lucamoiana/.qgis2/python’, u’/Users/lucamoiana/.qgis2/python/plugins’, ‘/Applications/QGIS.app/Contents/MacOS/…/Resources/python/plugins’, ‘/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7’, ‘/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7’, ‘/Library/Python/2.7/site-packages/numpy-override’, ‘/Library/Python/2.7/site-packages/matplotlib-override’, ‘/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages’, ‘/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.6/site-packages’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload’, ‘/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC’, ‘/Library/Python/2.7/site-packages’, ‘/Library/Python/2.7/site-packages/PIL’, ‘/Users/lucamoiana/.qgis2/python/plugins/mmqgis/forms’, ‘/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools’, ‘/Users/lucamoiana/Documents/GIS/Paolo’]
rivolgermi ?
Ciao.
Probabilmente meglio se apri un ticket:
https://github.com/geolicious/qgis2leaf/issues
Salluti.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
