[Gfoss] file map
Cari miei,sarà il sole,sarà il mare,ma a me questo file map non riesce farlo andare.Con maplab mi viene visualizzato solo l’elenco dei layer nel menù di sinistra però nella finestra centrale,dove teoricamente si dovrebbe caricare la mappa,non viene visualizzato niente…dove sta l’intoppo…copio di seguito il file incrminato!!!magari è la classica cavolata,però non riesco proprio a trovarla…
Grazie a tutti…!
Matteo
Start of axsum.map file
MAP
NAME “test”
STATUS ON
EXTENT -2200000 -712631 3072800 3840000
SIZE 400 300
SHAPEPATH “./data”
SYMBOLSET “./etc/symbols.sym”
FONTSET “./etc/fonts.txt”
IMAGETYPE PNG
IMAGECOLOR 255 255 255
UNITS METERS
Start of web interface definition
WEB
MINSCALE 2e+06
MAXSCALE 5e+07
On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
of the drive where the .MAP file resides.
IMAGEPATH “/tmp/ms_tmp/”
IMAGEURL “/ms_tmp/”
END
Start of reference object (ikonos_sharp)
REFERENCE
EXTENT 1496247 1332616 7055632 5502154 #2200000 1400000 8000000 5400000
IMAGE “library/webserver/documents/maplab/axsum/images/ikonos_sharp.png”
SIZE 199 149
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END # Reference
Start of querymap object
QUERYMAP
STATUS ON
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
Start of legend object
LEGEND
STATUS ON
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE “ttt”
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
Start of scalebar object
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
Start of OutputFormat object
OUTPUTFORMAT
NAME “png”
MIMETYPE “image/png”
DRIVER “GD/PNG”
EXTENSION “png”
IMAGEMODE PC256
TRANSPARENT FALSE
END
LAYER
NAME “ctour1”
TYPE LINE
DATA “ctour1”
TRANSPARENCY 30
CLASS
Name ‘ISOIPSE’
COLOR 200 254 199
OUTLINECOLOR 0 0 0
TEMPLATE void
END # Class
END # Layer
LAYER
NAME “Classic_Aksumite_new”
TYPE point
DATA “Classic_Aksumite_new”
TOLERANCE 10
TOLERANCEUNITS pixels
CLASS
NAME “Classic-Aksumite”
EXPRESSION ([POP_RANK] = 1)
COLOR 255 0 0
SYMBOL ‘square’
SIZE 9
LABEL
POSITION Auto
COLOR 0 0 150
BACKGROUNDCOLOR 255 255 128
BACKGROUNDSHADOWCOLOR 150 150 150
BACKGROUNDSHADOWSIZE 2 2
BUFFER 2
#TYPE truetype
#FONT verdana
#SIZE 8
#MAXSIZE 9
SIZE small
END #Label
TEMPLATE void
END # Class
END # Layer
LAYER
NAME “Early_Aksumite_new”
TYPE POINT
DATA “Early_Aksumite_new”
TOLERANCE 10
CLASS
NAME “Early-Aksumite-new”
COLOR 255 0 0
SYMBOL ‘square’
SIZE 9
LABEL
POSITION Auto
COLOR 0 0 150
BUFFER 2
#TYPE truetype
#FONT verdana
#SIZE 8
#MAXSIZE 9
SIZE small
END #Label
TEMPLATE void
END # Class
END # Layer
END #Map
farlo
andare.Con maplab mi viene visualizzato solo l'elenco dei layer nel menù
di
caricare
la mappa,non viene visualizzato niente...dove sta l'intoppo...copio di
proprio a trovarla...
Grazie a tutti...!
Matteo
Per prima cosa controlla che la temp directory sia esatta.
Magari in shppath/symbolset/fontset scrivi il percorso assoluto!
Hai provato con shp2img!
I log cosa dicono?
Ciao!
View this message in context: http://www.nabble.com/file-map-tf3901379.html#a11061895
Sent from the Gfoss mailing list archive at Nabble.com.
