[Gfoss] GDAL e ECW su linux
Ciao a tutti,
sto cercando di compilare le gdal con il supporto per gli ecw su ubunto 12.10-64bit ma senza successo. Ho seguito le istruzioni che ho trovato qui [0]
ma ottengo l’errore che ho riportato in calce [1]
stessa cosa se provo a compilare con il più classico ./configure --with-ecw=/usr/local/ecwjpg_sdk
Qualcuno ha idea di dove sto sbagliando ?
Grazie a tutti in anticipo
Luca
[0] http://makina-corpus.com/blog/metier/2013/howto-install-qgis-with-ecw-support-on-linux
[1] … /usr/local/ecwjp2_sdk/include/NCSMisc.h:207:80: error: expression list treated as compound expression in initializer [-fpermissive]
/usr/local/ecwjp2_sdk/include/NCSMisc.h:208:1: error: expected ‘,’ or ‘;’ before ‘{’ token
In file included from /usr/local/ecwjp2_sdk/include/NCSEcw/API/View.h:46:0,
from /usr/local/ecwjp2_sdk/include/NCSFile.h:18,
from gdal_ecw.h:59,
from ecwdataset.cpp:30:
/usr/local/ecwjp2_sdk/include/NCSEcw/SDK/Node2D.h:27:52: error: expected ‘}’ before end of line
/usr/local/ecwjp2_sdk/include/NCSEcw/SDK/Node2D.h:27:52: error: expected declaration before end of line
In file included from /usr/local/ecwjp2_sdk/include/NCSString.h:38:0,
from /usr/local/ecwjp2_sdk/include/NCSThread.h:44,
from /usr/local/ecwjp2_sdk/include/NCSUtil.h:67,
from /usr/local/ecwjp2_sdk/include/NCSEcw/API/View.h:37,
from gdal_ecw.h:59,
/usr/local/ecwjp2_sdk/include/NCSMisc.h:207:25: warning: ‘NCSGetIEEE4’ defined but not used [-Wunused-variable]
make: *** [ecwdataset.o] Error 1
