Qua sotto c’è la risposta di Jachym Cepicky, colui che ha fatto i repository per ubuntu, mi chiede aiuto per risolvere il bug del plugin GPS. Io non ne sono in grado…spero che qualcuno della lista lo possa fare.
Grazie e ciao
Luca
---------- Forwarded message ----------
Date: 1-feb-2007 14.46
Subject: GPS plugin in QGIS 0.8
To: qgis-developer@lists.qgis.org
Cc: Luca Delucchi < lucadeluge@gmail.com>
in the latest package generated with help of debian configuration
files the GPS plugin does not work:
I have sources of qgis 0.8 from svn
I have debian directory from qgis svn (current version of the conf.
files is 0.8-2)
I build the package using dpkg-buildpackage command
When I start qgis, I get following error message:
Failed to load /usr/lib/qgis/gpsimporterplugin.so
Reason: QLibrary::load_sys: Cannot load
(/usr/lib/qgis/libgpsimporterplugin.so: cannot open shared object
file: No such file or directory)
And really, libgpsimporterplugin.so is not in my system.
When I go to qgis_08/src/plugins/gps_importer and run “make”
everything seems to compile fine, but apparently now libgps* is
generated.
Could you help me please to get QGIS with GPS import plugin running?
Thanks
Jachym
2007/2/1, Luca Delucchi < lucadeluge@gmail.com>:
Hi, I have installed qgis with your repository but the plugin for GPS there
isn’t.
This is the problem:Failed to load /usr/lib/qgis/gpsimporterplugin.so
(/usr/lib/qgis/libgpsimporterplugin.so: impossibile aprire
il file oggetto condiviso: Nessun file o directory)Thank’s
Best regard
Luca Delucchi
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
