[Gfoss] [Gvsig_english] gvSIG 1.1-rc 1 (unstable) available
Volevo informarvi della "pubblicazione" della prima beta di gvSIG 1.1,
attenzione che ha come prerequisito la jre 1.5...per evitare problemi
vi consiglio di installare la versione che include anche i
prerequisiti...di seguito potete trovare maggiore informazioni...
Buona giornata
Simone
---------- Forwarded message ----------
Date: Jul 23, 2007 11:28 AM
Subject: [Gvsig_english] gvSIG 1.1-rc 1 (unstable) available
To: Gvsig_internacional@runas.cap.gva.es
Hello,
we inform you that gvSIG is initiating the stabilisation process of the
next version 1.1. Already available is the first draft of the version
gvSIG 1.1-rc1, it can be found under
http://www.gvsig.gva.es/index.php?id=1731&L=0&L=2 (Downloading the
program).
Hereby, we would like to encourage you to participate in this project by
informing us about any detected error, simplest way by the means of the
e-mail distribution list.
Definitely, we appreciate every kind of feedback and suggestion.
New features of this version:
- Installation:
- gvSIG installation includes now JAI 1.1.3
- JCRS Extension:
- Now integrated in the installation.
- geoDB:
- Field Calculator:
- It automatically fills table fields by calculating from values in the
same table or geometry properties like area, length, etc.
- Annotation Layer:
- It can be generated from feature layers with any kind og geometry, not
just points.
- A new independent non-virtual layer is created and persisted as shp.
The original layer is not removed from the View.
- The table associated to the new shp file contains fields for Text,
Font, Color, Height and Rotation.
- There is a new menu option "Properties of annotation layer", where it
is possible to choose units (meters or pixels), to draw text only, etc.
- In the "Add Layer" dialog, a new tab allows loading of Annotation layers.
- The process can eliminate duplicated labels.
- The annotation layer can be generated from selected features.
- The process can eliminate overlapping labels.
- PostGIS:
- When exporting to PostGIS, it is possible to specify the database
Schema name to save to.
We count on your collaboration.
Kind regards
Mario Carrera Rodríguez
Grupo SIG-CAD / gvSIG
Asistencia técnica externa
Servicio de Organización e Informática
Conselleria d'Infraestructures i Transport
Generalitat Valenciana
Valencia (España)
Gvsig_internacional mailing list
http://runas.cap.gva.es/mailman/listinfo/gvsig_internacional
Per il momento l'ho provata solo su win e, con grande piacere, ho
notato le interessanti novità:
- l'integrazione del jCRS e del geoDB;
- il Field Calculator ... anche in ottica ECDL-GIS;
- migliorie nella gestione dei layer PostGIS;
- annotation layer;
- perfetta compatibilità con gli script creati con le precedenti versioni.
Sono d'accordo con te sul fatto di installare le versioni "withJRE" al
fine di evitare problemi post installazione. Per il resto, pare
abbastanza stabile... Chissà se è compatibile con SEXTANTE for gvSIG e
le estensioni della 1.0.2?
Ciao
Antonio
Buona giornata
Simone
Hello,
program).
- Installation:
- JCRS Extension:
- geoDB:
- Field Calculator:
- Annotation Layer:
just points.
- PostGIS:
Kind regards
Valencia (España)
Gfoss mailing list: 234 iscritti (13-07-2007)
Gfoss@faunalia.com
http://www.faunalia.com/cgi-bin/mailman/listinfo/gfoss
