Innanzitutto, buone feste fatte a tutta la lista! Ne approfitto per
segnalare un piccolo regalo dalla comunità gvSIG, come da msg allegato.
Si tratta essenzialmente di un bug fixing, una patch che corregge alcuni
problemi riscontrati nella 1.1, che pertanto non va disinstallata.
Ciao
Antonio
-------- Messaggio Originale --------
Oggetto: [Gvsig_english] gvSIG update version 1.1.1 is available
Data: Thu, 27 Dec 2007 11:39:00 +0100
Da: Jordi Beltrán
Rispondi-a: Users and Developers mailing list
<gvsig_internacional@runas.cap.gva.es>
A: gvsig_internacional@runas.cap.gva.es
gvSIG 1.1.1, a partial update of gvSIG 1.1, is now available for
download in which some problems detected by our users have been fixed,
so it is possible to working normally with the application.
As usual, it can be downloaded from the Download section of the web page
(http://www.gvsig.gva.es/index.php?id=gvsig11&L=2).
Warning: to install the partial update you must have gvSIG 1.1 correctly
installed.
The problems fixed in this distribution are:
- Tables:
* In some shapefiles, empty records appear.
- Oracle Spatial:
* Problems when exporting to Oracle Spatial.
- Editing:
* Introducing points with absolute polar coordinates doesn't work.
- DGN Files:
* Problems when exporting this kind of files to DXF format.
- GML Files:
* Problems when exporting this kind of files to GML format.
* Problems when exporting this kind of files to PostGIS format.
- Export to pdf:
* When changing page properties, export to PDF fails recalculating
the position of some elements.
- Other:
* When opening an existing project containing a layer whose path has
changed, if the table associated to it is not removed from the Project
manager, then the console pops up.
Gvsig_internacional mailing list
Gvsig_internacional@runas.cap.gva.es
http://runas.cap.gva.es/mailman/listinfo/gvsig_internacional
