[Gfoss] Help! Primi passi con MapServer + Openlayers
mi sembra che forse ti manca qualcosa nel file .map
tipo fontset e symbolset outputformat e proj
tipo una cosa del genere
MAP
  NAME "QGIS-MAP"
  # Map image size
  SIZE 100 100
  UNITS meters
  EXTENT 300130.527053 4386590.110820 300173.213080 4386615.936841
  FONTSET './fonts/fonts.txt'
  SYMBOLSET './symbols/symbols.txt'
  PROJECTION
    'proj=utm'
    'zone=42'
    'datum=WGS84'
    'units=m'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE agg
  OUTPUTFORMAT
    NAME agg
    DRIVER AGG/PNG
    IMAGEMODE RGB
  END
  IMAGEPATH '/tmp/'
  IMAGEURL '/tmp/'
  #WMS server settings
    METADATA
      'ows_title' 'QGIS-MAP'
      'ows_onlineresource' '
http://my.host.com/cgi-bin/mapserv.exe?map=C:/Users/user/Documents/ssss.map
      'ows_srs' 'EPSG:32642'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See
MapServer documentation
    TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
  END
  LAYER
    NAME 'tr9_p'
    TYPE POLYGON
    DUMP true
    TEMPLATE fooOnlyForWMSGetFeatureInfo
    DATA './convegno 27_maggio_2014_kojtepa/tr9_p.shp'
    METADATA
      'ows_title' 'tr9_p'
    END
    STATUS OFF
    TRANSPARENCY 100
    PROJECTION
    'proj=utm'
    'zone=42'
    'datum=WGS84'
    'units=m'
    'no_defs'
    END
    CLASS
       NAME 'tr9_p'
       STYLE
         WIDTH 0.91
         OUTLINECOLOR 0 0 0
         COLOR 182 109 194
       END
    END
  END
(questo è un mio esempio su un sistema di rif utm42N)
fa sapere.
ciao
enzo
