[Gfoss] installazione moduli grass dietro ad un proxy
Ciao a tutt*,
stiamo utilizzando GRASS Versione 7.4.4
in ambiente Windows
e non riusciamo ad installare moduli su grass
all'interno della nostra rete con proxy.
Il comando che stiamo utilizzando è:
C:\>g.extension extension=r.geomorphon
proxy="http=http://user:passowrd@url_proxy:port_proxy"
L'errore che otteniamo è:
Downloading precompiled GRASS Addons <r.geomorphon>...
  File "C:\PROGRA~1\QGIS3~1.4\apps\grass\grass-7.4.4/scripts/g.extension.py",
line 1748, in <module>
    sys.exit(main())
line 1727, in main
    install_extension(source=source, url=url, xmlurl=xmlurl)
line 684, in install_extension
    ret += install_extension_win(module)
line 957, in install_extension_win
    outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
line 1098, in download_source_code
    f, h = urlretrieve(url, zip_name)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\urllib.py", line 98, in
urlretrieve
    return opener.retrieve(url, filename, reporthook, data)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\urllib.py", line 245, in
retrieve
    fp = self.open(url, data)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\urllib.py", line 213, in
open
    return getattr(self, name)(url)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\urllib.py", line 350, in
open_http
    h.endheaders(data)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\httplib.py", line 1038, in
endheaders
    self._send_output(message_body)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\httplib.py", line 882, in
_send_output
    self.send(msg)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\httplib.py", line 844, in
send
    self.connect()
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\httplib.py", line 821, in
connect
    self.timeout, self.source_address)
  File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\socket.py", line 575, in
create_connection
    raise err
IOError: [Errno socket error] [Errno 10060] Impossibile stabilire la
connessione. Risposta non corretta della parte connessa dopo l'intervallo
di tempo oppure mancata risposta dall'host collegato
Abbiamo fatto diverse prove, ma non riusciamo a trovare una combinazione
funzionante. Avete qualche dritta?
Grazie.
PS.
purtroppo non posso cambiare sistema operativo o intervenire sulla
configurazione di rete.
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Marica Landini
On Mon, 25 Feb 2019 at 13:55, Marica Landini <bulma@ferrara.linux.it> wrote:
Ciao a tutt*,
Ciao,
in ambiente Windows
    sys.exit(main())
line 1727, in main
urlretrieve
retrieve
open
open_http
    h.endheaders(data)
endheaders
_send_output
    self.send(msg)
send
    self.connect()
connect
create_connection
    raise err
per risolvere il problema dovresti scrivere in una lista
internazionale user o dev [0].
Per aggirarlo invece puoi scaricare i sorgenti del modulo da qui [1]
(controlla che la versione di GRASS sia corretta) e copiare i file
nelle cartelle corrette, di solito la cartella dove scrivere è
$HOME/.grass7/addons/
fammi sapere se funzione
Grazie.
[0] https://grass.osgeo.org/support/mailing-lists/
[1] http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/r.geomorphon.zip
ciao
Luca
www.lucadelu.org
