[Gfoss] Lizmap 2.9 is out!
Fresco fresco:
https://github.com/3liz/lizmap-web-client/releases/tag/2.9.0
Un bel po' di novita', alcune davvero interessanti:
Home page - Add a button showing map metadata window for each project
Home page - Hide project and restrict access if option set in Lizmap plugin
Locate by layers - Add hierarchical searches based on attribute or based
on vector attributes joins
Map - Use initial extent defined by the project admin (via plugin)
instead of full map extent on start
Map - Baselayers : Add Bing maps , OpenCycleMap and IGN Geoportal
Map - Baselayers : enable to use external Lizmap layers from other
projects as baselayers
Map - Add a permalink to share current map position and active layers
Map - Use QGIS project background color as the background color of the
web map
Print feature - Add scale selection
Print feature - Add multi-printing based on project composers
Filter by user group - Filter layers features by authenticated user group id
Timemanager - animate vector layers based one time attribute
Buon divertimento.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
