[Gfoss] Problema Mapserver
Scusate, adesso dovrei essere iscritto
Salve a tutti,
mi accingo adesso a lavorare con Mapserver, sono ancora parecchio inesperto
su vari fronti, spero siate clementi.
Ho vari problemi:
1) Non riesco ad usare il plugin di QGIS MapServer Exporter, il quale
dovrebbe esportare in formato .map gli shape file creati con Qgis. L'errore
risulta essere questo:
Errore durante l'esecuzione di codice Python:
File "C:/Users/S/.qgis2/python/pluginsrt_mapserver_exporterplugin.py", line
65, in run
from .mapfileexportdlg import MapfileExportDlg
File "C:/PROGRA~1/QGISWI~1/apps/qgis/./pythonqgisutils.py", line 478, in
_import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"C:/Users/S/.qgis2/python/pluginsrt_mapserver_exportermapfileexportdlg.py",
line 30, in
import mapscript
_import
File "C:PROGRA~1QGISWI~1appsPython27libsite-packagesmapscript.py", line 25,
in
_mapscript = swig_import_helper()
File "C:PROGRA~1QGISWI~1appsPython27libsite-packagesmapscript.py", line 17,
in swig_import_helper
import _mapscript
_import
ImportError: No module named _mapscript
Versione Python:
2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
Versione di QGIS:
2.8.1-Wien Wien, exported
Percorso Python: ['C:/Users/S/.qgis2/python/pluginsprocessing',
'C:/PROGRA~1/QGISWI~1/apps/qgis/./python', u'C:/Users/S/.qgis2/python',
u'C:/Users/S/.qgis2/python/plugins',
'C:/PROGRA~1/QGISWI~1/apps/qgis/./python/plugins',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesmatplotlib-1.3.1-py2.7-win-amd64.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesnose-1.3.3-py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagestornado-4.0.1-py2.7-win-amd64.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesbackports.ssl_match_hostname-3.4.0.2-
py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagescertifi-14.05.14-py2.7.egg',
'C:PROGRA~1QGISWI~1binpython27.zip', 'C:PROGRA~1QGISWI~1appsPython27DLLs',
'C:PROGRA~1QGISWI~1appsPython27lib',
'C:PROGRA~1QGISWI~1appsPython27libplat-win',
'C:PROGRA~1QGISWI~1appsPython27liblib-tk', 'C:PROGRA~1QGISWI~1bin',
'C:PROGRA~1QGISWI~1appsPython27',
'C:PROGRA~1QGISWI~1appsPython27libsite-packages',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesPIL',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesjinja2-2.7.2-py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesmarkupsafe-0.23-py2.7-win-amd64.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagespytz-2012j-py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packageswin32',
'C:PROGRA~1QGISWI~1appsPython27libsite-packageswin32lib',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesPythonwin',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesShapely-1.2.18-py2.7-win-amd64.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagessix-1.3.0-py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packageswx-2.8-msw-unicode',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesxlrd-0.9.2-py2.7.egg',
'C:PROGRA~1QGISWI~1appsPython27libsite-packagesxlwt-0.7.5-py2.7.egg',
u'C:/Users/S/.qgis2//python', 'C:UsersS.qgis2pythonpluginsmmqgis/forms',
'C:PROGRA~1QGISWI~1appsqgispythonpluginsfToolstools']
Ho cercato nei forum di capire il perché di questo errore Python ma non ne
sono venuto a capo, per questo chiedo a voi.
In alternativa c'è un altro modo per creare dei file .map a partire da shape
file già esistenti?
2)Ho scaricato, almeno credo, tutto quello che c'era da scaricare: ms4w,
apache, ecc. Il test http://localhost/cgi-bin/mapserv.exe? dà esito
positivo: No query information to decode. QUERY_STRING is set, but empty.
Quando provo a visualizzare un file .map qualsiasi però non riesco a farlo,
cioè il test "shp2img –m mappa.map –o immagine.png" non va (shp2img non
riconosciuto), eppure c'è una cartella.
Allo stesso modo se inserisco nel browser
"http://localhost/cgi-bin/mapserv.exe?map=c:/mapserver_quickstart.map" la
risposta è: mapserv(): Web application error. Traditional BROWSE mode
requires a TEMPLATE in the WEB section, but none was provided.
Il file .map che vorrei testare é:
MAP
NAME "MAPSERVER QUICKSTART"
EXTENT -137 29 -53 88
UNITS DD
SHAPEPATH "c:/"
SIZE 800 600
IMAGETYPE PNG24
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
ows_enable_request "*"
END
END
LAYER
NAME "Admin Countries"
STATUS ON
TYPE POLYGON
DATA "ne_10m_admin_0_countries"
CLASS
STYLE
COLOR 246 241 223
OUTLINECOLOR 0 0 0
END
END
END
END
Dove sbaglio?
Probabilmente non sono stato chiaro perché non sono ancora del tutto chiari
a me i vari passaggi svolti, grazie alle vostre eventuali risposte riuscirò
sicuramente a ricostruire il tutto.
Vi ringrazio,
Sandro
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/Problema-Mapserver-tp7594727p7594750.html
l'errore python dice che manca il modulo _mapscript, ma non ti so dire
come installarlo in windows, se lo trovi basta copiarlo nella cartella
di python sotto windows.
l'altro errore è dato dalla web application e manca appunto un
template nella sezione WEB del tuo file. ms4w dovrebbe installare
pmapper con un map file di esempio da cui puoi copiare un template.
vado a memoria e sono da cell
dallo shapepath pare che il tuo shapefile è salvato in c:\
ne_10m_admin_0_countries.shp è corretto?
amefad
2015-10-29 19:02 GMT+01:00 Sandrus <sandro.picone@yahoo.it>:
Salve a tutti,
Ho vari problemi:
65, in run
_import
File
line 30, in
import mapscript
_import
in
import _mapscript
_import
Versione Python:
Versione di QGIS:
py2.7.egg',
file già esistenti?
"http://localhost/cgi-bin/mapserv.exe?map=c:/mapserver_quickstart.map&quot; la
MAP
UNITS DD
SHAPEPATH "c:/"
SIZE 800 600
IMAGETYPE PNG24
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
END
END
LAYER
STATUS ON
TYPE POLYGON
CLASS
STYLE
COLOR 246 241 223
OUTLINECOLOR 0 0 0
END
END
END
END
Dove sbaglio?
Vi ringrazio,
Sandro
Gfoss@lists.gfoss.it
786 iscritti al 30.9.2015
qualcuno sa dove è la documentazione di questi widget aggiuntivi?
non sono ancora riuscito a trovarla tramite google
se qualcuno ha il link , qualcuno li ha usati ? che esperienza ne ha ?
saluti
Grazie mille per la risposta.
Per quanto riguarda il primo errore continuo a non capire, ho scaricato il
modulo "mapscript", possibile che esista anche il modulo "_mapscript"? In
ogni caso non sono riuscito a trovarlo.
Sull'altro "fronte" dovrei aver risolto, c'erano alcuni errori nel file
.map, uno tra questi era proprio il percorso dello shape file.
Grazie
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/Problema-Mapserver-tp7594727p7594776.html
