[Gfoss] PS TIME PROBLEMA URGENTE
Per Paolo Cavallini
Ciao
ecco l'errore:
ERROR|Sat Jan 17 2015 12:20:57|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sat Jan 17 2015 12:20:57|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sat Jan 17 2015 12:20:59
ERROR|Sat Jan 17 2015 12:28:11|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sat Jan 17 2015 12:28:11|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sat Jan 17 2015 12:28:11
ERROR|Sun Jan 18 2015 18:30:58|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sun Jan 18 2015 18:30:58|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sun Jan 18 2015 18:30:59
ERROR|Mon Jan 19 2015 01:09:29|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Mon Jan 19 2015 01:09:29|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Mon Jan 19 2015 01:09:30
ERROR|Mon Jan 19 2015 09:05:26|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Mon Jan 19 2015 09:05:26|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Mon Jan 19 2015 09:05:30
Il 19/01/2015 09:45, andrea.scaglia ha scritto:
Per Paolo Cavallini
Ciao
ecco l'errore:
Salve.
Cosi' non credo che altri capiscano.
Comunque l'errore e' legato a OTB, non ha a che fare con il plugin PS Time.
Saluti.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
