[Gfoss] [Qgis-developer] LTR
Slave.
Pubblicato QGIS 2.8. L'importante novita' e' che questa e' una versione
a lungo termine, che avra' una serie di rilasci con la sistemazione dei
bugs (ma non nuove funzioni), man mano che questi saranno disponibili.
Invitiamo tutti gli interessati a finanziare la sistemazione dei bugs,
in modo da avere una versione sempre piu' stabile.
Credo che questo sara' un bel cambiamento soprattutto per chi opera
all'interno di grandi strutture, dove l'aggiornamento di nuove versioni
e' spesso un problema.
Cordiali saluti.
-------- Messaggio Inoltrato --------
Oggetto: [Qgis-developer] LTR
Data: Mon, 2 Mar 2015 14:00:39 +0100
Mittente: Jürgen E. Fischer <jef@norbit.de>
A: qgis-developer@lists.osgeo.org
I started to including the LTR release in the packaging/nightly builds. I'm
going to change the plan/procedure a bit. Both regular release and ltr
will
be branched of master and continue to be called release-$major_$minor.
The LTR
additionally gets a ltr-$major_$minor tag. release.pl is already
changed that
way any release-2_8 has such a tag.
A cronjob will monitor release branches for changes and intiate a new point
release whenever there are two week silence after a new commit (or manually
when there was a very important fix).
The nightly builds will monitor master, latest release and ltr branch and
create nightly packages if there are changes (1+2+4), unless there was a
version change (ie. a point release) in which case regular packages will be
made (3+5).
For Windows there will be five different packages (1-5: qgis-dev,
qgis-rel-dev,
qgis, qgis-ltr-dev, qgis-ltr) in OSGeo4W, for debian/ubuntu there will
be five
different repositories (1-5: debian-nightly, debian-nightly-release, debian,
debian-lts-nightly, debian-lts).
4+5 are only made if the latest release and ltr branch are different. Until
then latest release and ltr are identical anyway. That also means ltr
packages
only start four months after a ltr release happened and we maintain the ltr
branch four months as our regular and nine specifically as separate ltr
release. That also implies that installing ltr packages means that you
install
something that already has seen four months of maintainance.
An open question is what to do in the four month a new ltr is out.
While there
is no new regular release only regular packages are created and there are no
new ltr packages. This might be negligible as the ltr branch will have been
maintained for a year as promised, but if you only install ltr packages
there
will be a gap of four months without updates. But I guess that can be left
open until we get there.
Thoughts?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on
FreeNode
Ciao Paolo,
Purtroppo questa versione qui ha ancora un limite bruttarello:
non ha ancora i sistemi di riferimento EPSG:6007 (e questo il codice
giusot?) che sono quelli da usare in Italia.
Proprio in quesit giorni stanno rilasciando le PROJ che supportano
questi nuovi codici epsg.
Per cui non entreranno in questa versione di qgis, ma nella prossima (forse).
Per cui dire che in Italia si lavora per un anno con una versione che
non supporta i nuovi codici epsg e' complicato.
Mi spiego meglio:
se tra 3 mesi esce una nova versione di qgis, che supporta i codici
epsg dell''IGM (molto probabile a questo punto).
Come si fa' a dire che per un tempo pari a LTR si deve lavorare e
investire in risoluzione di bugs di una versione che diventerebbe per
forza di cose obsoleta subito
appena esce la nuova con i nuovi sistemi di riferimento ?
Differente sarebbe se ci fosse la CERTEZZA che quando le proje nuove
escono , in questa LTR entrerebbero loro e i db deisistemi di
rifiermneto venissero aggiornati.
Ma sinceramente io dubito di questo , perche' non e' un bug e quindi
non verrebbe accettato come facente parte della gestione LTR.
NOn so se sono riuscito a spiegarmi.
Andrea.
2015-03-02 15:31 GMT+01:00 Paolo Cavallini <cavallini@faunalia.it>:
Slave.
Cordiali saluti.
will
The LTR
changed that
made (3+5).
qgis-rel-dev,
be five
packages
install
While there
there
Thoughts?
Jürgen
FreeNode
Gfoss@lists.gfoss.it
666+40 iscritti al 5.6.2014
Andrea Peri
qwerty àèìòù
No. i codici verranno aggiunti in una prossima release, se qualcuno fa
(o finanzia) il backport.
Non credo sia unh problema, non e' una nuova feature di QGIS, e'un
aggiornamento delle librerie, peraltro probabilment einnocuo.
Saluti, e grazie della segnalazione.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Ma è stata già pubblicata cartografia col nuovo sistema ETRF2000 ?
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/Fwd-Qgis-developer-LTR-tp7591652p7591668.html
Sì ad esempio ortofoto e dtm 5x5 m2 di regione piemonte sono in etrf2000 ma
non essendoci anc0ra i prj sono stati pubblicati accompagnandoli da
epsg:32632
s.
View this message in context: http://gfoss-geographic-free-and-open-source-software-italian-mailing.3056002.n2.nabble.com/Fwd-Qgis-developer-LTR-tp7591652p7591669.html
Non ho capito a cosa si riferisce il tuo "no".
A.
Andrea Peri
qwerty àèìòù
Aggiungo il ticket con cui e' stato inserito dall'ottimo Even Rouault
i codici italiani nel db delle proj.
I codici erano epsg:6704-6711 e non 6700 (ricordavo male...)
http://trac.osgeo.org/proj/ticket/236
A.
A.
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
Intendevo: l'affermazione "non entreranno in questa versione di qgis" e'
falsa. L'aggiornamento delle librerie e' ampiamente possibile, se
qualcuno lo realizza.
Saluti, e grazie per la precisazione.
On Wed, 04 Mar 2015 08:48:46 +0100
sono passati diversi mesi ormai dall'aggiornamento delle proj, e tre versioni di QGis.
l'anno scorso mi pareva di aver capito che la ricompilazione di QGis recuperasse le librerie nuove.
Evidentemente non è così. A chi si può chiedere tra i "qualcuno" per realizzare l'aggiornamento?
grazie
Marco Guiducci <marco.guiducci@regione.toscana.it>
Firenze, via di Novoli 26
055 4383194
Il meglio è aprire un ticket su osgeo4w.
Saluti.
Il 04 marzo 2015 18:57:04 CET, Marco Guiducci marco.guiducci@regione.toscana.it ha scritto:
grazie
http://faunalia.eu/
Sent from mobile, sorry for being short
