Salve a tutti,
qualcuno sa come si risolve il problema delle librerie esterne richieste dai plugin ?
Dove vanno inserite ? Si possono inserire all’interno del plugin, invece di doverle inserire all’interno di ogni nuova versione di QGIS, come ad esempio :
QGIS VERSIONE\apps\Python27\Lib\site-packages\
A proposito di questo, di seguito c’è il messaggio di Victor Olaya che ho trovato all’interno della lista qgis-dev , ma non riesco a far funzionare le sue istruzioni. Qualcuno può aiutarmi ?
Penso sia un problema che interessa parecchi sviluppatori di plugin.
Grazie per qualunque info in proposito
A presto
Roberto
2015-10-07 17:50 GMT+02:00 Victor Olaya <volayaf@gmail.com>:
At the moment, you have to ship them with your plugin, in the plugin
zip file. If the lib uses native code, you will need to include
binaries for all OSs that you want to support, and the corresponding
mechanism to pick one or the other.
As an example, you can see how it is done in this plugin
https://github.com/boundlessgeo/qgis-geoserver-plugin/blob/master/src/geoserverexplorer/init.py
Dependencies are stored in a folder called “ext-libs”, which is added
to the python path by the plugin
Notice that that folder is not in the repo, there is a paver task to
fetch the dependencies from PyPi
Notice also that QGIS has its folder with python libs
https://github.com/qgis/QGIS/tree/master/python/ext-libs
Make sure that the libs you require are not already in there
In my case ( GEarthView QGIS plugin ) I have two external libraries:
twisted
zope
that I need to install manually
On windows, they need to be copied for each new version of QGIS, inside the folder:
QGIS VERSION\apps\Python27\Lib\site-packages\
Instead, on MacOSX, they are (once and for all) inside the standard python library folder, as I explained in my blog:
http://exporttocanoma.blogspot.it/2015/01/gearthview-20-plugin-per-qgis.html
I have tried several times to make sure that it was not necessary to install anything, including the libraries in my plugins, so far I have not succeeded. So, that your message has rekindled my hopes
but there are some things I do not understand, in your explanation (my fault).
Here are my steps:
- I modified my geodrinx/init.py adding:
site.addsitedir(os.path.abspath(os.path.dirname(file) + ‘/ext-libs’))
Question: where need I to create this ext-libs folder ? I looked into the plugin that you indicate, but I found no “ext-libs” folder.
Could you please explain me (us) better ?
Thank you much
A presto
Roberto
Il 22/10/2015 09:01, Geo DrinX ha scritto:
Salve a tutti,
dai plugin ?
si parla di Windows, vero? Su Linux (non sono sicuro di OSX) basta
avvisare l'utente di installare il pacchetto necessario. Magari va
trovato un modo piu' evidente rispetto ai messaggi di errore attualmente
mostrati nella maggior parte dei casi.
Saluti.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
On 22 October 2015 at 09:01, Geo DrinX <geodrinx@gmail.com> wrote:
Salve a tutti,
ciao,
plugin ?
Dove vanno inserite ? Si possono inserire all'interno del plugin, invece
di doverle inserire all'interno di ogni nuova versione di QGIS, come ad
esempio :
A proposito di questo, di seguito c'è il messaggio di Victor Olaya che ho
trovato all'interno della lista qgis-dev , ma non riesco a far funzionare
io faccio così:
- installo pip per windows utilizzando la console di OSGeo
- con pip installo la dipendenza che mi manca.
A presto
Roberto
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Il giorno 22 ottobre 2015 09:09, Paolo Cavallini <cavallini@faunalia.it> ha
scritto:
> Salve a tutti,
> dai plugin ?
Sì. Si parla di Windows. Si parla di un sistema operativo che ha qualche
centinaio di milioni di utenti
Su Linux e su Mac il problema non esiste, perchè basta che le librerie
siano installate sotto (gli unici) ambienti Python.
Però, in tutte le versioni Desktop di QGIS Windows questo problema esiste,
e mi trovo oltre 100mila persone che mi scrivono chiedendomi dove vanno
installate le librerie twisted e zope
@Alessandro
La policy è quella di non distribuire mai coi plugin le librerie ma
fornire istruzioni per l'installazione: sopratutto se sono
disponibili su pypi e installabili con pip o easy_install o apt o altri
package manager).
Benissimo. Farò seguire questa policy ai miei centomila utenti.
Comunque, per curiosità, qualcuno sa come si installa una volta sola su
Windows le librerie twisted e zope, senza doverle ripetere all'interno di
tutte le versioni di QGIS ?
Possibilmente utilizzando solo le versioni Desktop "QGIS Standalone
installer" (e non quelle OsgeoW") ?
Grazie per le info
Roberto
2015-10-22 9:22 GMT+02:00 Geo DrinX <geodrinx@gmail.com>:
sbaglio o victor ti ha suggerito una soluzione per creare un plugin
autoconsistente?
Roberto
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
