riprodotto
ecco il trace dell’errore che puoi allegare al tiket
#0 0x00007ffff33bbb56 in QString::operator==(QString const&) const () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#1 0x00007ffff4986151 in QgsSvgCache::cacheEntry (this=0x7ffff50580c0, file=…, size=75.59055118110237, fill=…, outline=…, outlineWidth=3.7795275590551185, widthScaleFactor=3.7795275590551185,
rasterScaleFactor=1) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgssvgcache.cpp:457
#2 0x00007ffff4983d39 in QgsSvgCache::svgAsImage (this=0x7ffff50580c0, file=…, size=75.59055118110237, fill=…, outline=…, outlineWidth=3.7795275590551185, widthScaleFactor=3.7795275590551185,
rasterScaleFactor=1, fitsInCache=@0x7fffffff988f: true) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgssvgcache.cpp:113
#3 0x00007ffff491e5a6 in QgsSVGFillSymbolLayer::applyPattern (this=0x8fa95e0, brush=…, svgFilePath=…, patternWidth=20, patternWidthUnit=QgsSymbolV2::MM, svgFillColor=…, svgOutlineColor=…,
svgOutlineWidth=1, svgOutlineWidthUnit=QgsSymbolV2::MM, context=…) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgsfillsymbollayerv2.cpp:1626
#4 0x00007ffff491eab1 in QgsSVGFillSymbolLayer::startRender (this=0x8fa95e0, context=…) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgsfillsymbollayerv2.cpp:1662
#5 0x00007ffff48d70b9 in QgsFillSymbolLayerV2::drawPreviewIcon (this=0x8fa95e0, context=…, size=…) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgssymbollayerv2.cpp:377
#6 0x00007ffff48d06e1 in QgsSymbolV2::drawPreviewIcon (this=0x8fa9b50, painter=0x7fffffffaf50, size=…) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/symbology-ng/qgssymbolv2.cpp:275
#7 0x00007ffff4bd9a27 in QgsComposerLegend::drawSymbolV2 (this=0x8f8ba10, p=0x7fffffffaf50, s=0x8fa9b50, currentYCoord=84.400000000000006, currentXPosition=@0x7fffffff9db8: 2, symbolHeight=@0x7fffffff9de0: 4)
at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/composer/qgscomposerlegend.cpp:542
#8 0x00007ffff4bd865f in QgsComposerLegend::drawSymbolItem (this=0x8f8ba10, symbolItem=0x8fa7310, painter=0x7fffffffaf50, point=…, labelXOffset=9)
at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/composer/qgscomposerlegend.cpp:379
#9 0x00007ffff4bddebd in QgsComposerLegend::drawAtom (this=0x8f8ba10, atom=…, painter=0x7fffffffaf50, point=…) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/composer/qgscomposerlegend.cpp:937
#10 0x00007ffff4bd6111 in QgsComposerLegend::paintAndDetermineSize (this=0x8f8ba10, painter=0x7fffffffaf50) at /home/ginetto/PROGRAMMING/QGIS-2.0-master/src/core/composer/qgscomposerlegend.cpp:144
#11 0x00007ffff4bd5a47 in QgsComposerLegend::paint (this=0x8f8ba10, painter=0x7fffffffaf50, itemStyle=0x7fe58a8, pWidget=0x2bbef60)
2014-04-29 13:09 GMT+02:00 Luca Mandolesi <mandoluca@gmail.com>:
Grazie al fatto che tengo sempre più versioni, ho ancora la 2.0 installata che mi apre il qpt. L’errore è dato dalla scala, che diventa un unico quadrato nero sul map composer. Questo problema è stato riscontrato su almeno 20 macchine di un corso che ho tenuto, dove, aprendo i qpt, della stessa versione, ma con viste a zoom differenti, la scala poteva diventare una linea a 45 gradi che corre fino all’infinito…l’unico modo di sanare la cosa è eliminare la scala.
Credo sia un bug noto e non ho nemmeno riverificato visto che appariva su varie macchine con SO diversi…ho fatto male?
Gfoss@lists.gfoss.it
666 iscritti al 22.7.2013
Il giorno 29 aprile 2014 12:47, Luca Mandolesi <mandoluca@gmail.com> ha scritto:
@Paolo: ma io sono terrorizzato!
Cmq per me non c’è problema al fatto che devo rifare le cose e contribuire allo sviluppo, temo per l’elasticità di chi deve lavorare non potendo decidere e anelo a che tali sistemi siano compatibili per una maggior diffusione.
Detto questo, ecco il link: https://dl.dropboxusercontent.com/u/32702124/A3_prova.qpt
Purtroppo mi va subito in crush qgis, quindi non ho il tempo di far nulla.
Mi piacerebbe comprendere cosa lo fa andare in crush e magari con una semplice modifica del codice editarlo in maniera testuale…
Ciao
Luca
Il giorno 29 aprile 2014 12:27, Andrea Fredduzzi <andreafredd@gmail.com> ha scritto:
Il giorno 29 aprile 2014 11:52, Luca Mandolesi <mandoluca@gmail.com> ha scritto:
Ciao a tutti,
ho realizzato una serie di qpt con la 1.8 di Qgis e ora con la 2.2 mandano in crush qgis. C’è modo di capire cosa manda tutto in crush e se la cosa è risolvibile?
Non credo che si possano recuperare, ma questo mette sempre un po’ il dito nella piaga della produttività a lungo termine di cui si parlava un po’ di tempo fa in lista per QGis. Per esempio, ora che vorrei proporre ad una PA Qgis, tremo al pensiero che al passaggio di versione tutto non funzioni più.
Io ho risolto semplicemente risalvando lo stile e ricaricandolo, non avevo un crash immediato ma dopo qualche operazione di panning. Hai provato?
Andrea Fredduzzi (phD)
Dipartimento di Fisica e Geologia
Università di Perugia
Via G. Duranti 93/a - 06125 Perugia (Italy)
e-mail: andrea.fredduzzi@unipg.it - andreafredd@gmail.com
tel: +39(0)755853760 - fax: +39(0)755853756
