pare che il bug sull'installazione dei plugins python in qgis sia a posto.
ora lo provo.
pc
-------- Messaggio Originale --------
I submitted a trac bug report for what is probably the same issue.
When the python code tries to unzip the files from the zip, it fails
if the top-level folder isn't an item in the zip. At least on Windows
anyway.See the trac bug for details. The fix is to check the paths for '/'
and create directories that way. Not yet implemented...
Barry,
I guess you mean this ticket:
https://svn.qgis.org/trac/ticket/890
I've tested Gary's recent fix for that and with it installs plugins
correctly.
Paolo Cavallini, see: http://www.faunalia.it/pc
