[Gfoss] Re: [Qgis-user] Spatialite : problems with spatial views
Salve.
Ho seguito la discussione un po' al volo, ma mi pare che questa nota aiuti a capire
(se no, scusatemi).
Saluti.
-------- Messaggio originale --------
Oggetto: Re: [Qgis-user] Spatialite : problems with spatial views
Data: Wed, 05 Feb 2014 12:26:55 +0200
Mittente: Micha Silver <micha@arava.co.il>
A: giedrius <gvaivilavicius@gmail.com>, qgis-user@lists.osgeo.org
Notice that you have duplicate ROWID values in your view results. Spatialite (and DB
manager) don't care about this since the ROWID is more a convenience. But for QGIS
it's critical that this column be like a unique primary key.
This is happening because you have GROUP BY with two columns in your query. I think
that what will resolve this is creating a new integer column with unique values for
each Fortas-rusis pair.
If you could try this: add to both the siksnosparniai_rusis table and the
siksnosparniai_patalpa tables additional integer columns with unique values for each
Fortas and unique values for each rusis. Then in your view, combine these two
integers in some way to get a new *unique* value to be used as the ROWID. That should
work out the duplicate error values in QGIS.
Good luck,
Micha
On 05/02/2014 09:25, giedrius wrote:
Hello,
I have a problem with the display of tables add to QGIS from spatialite.
DB Manager displays the correct data, but uploading to QGIS table entries
changed to false:
http://i.imgur.com/Pahw13c.png
http://i.imgur.com/9Y1zaq4.png
When loaded data export to shapfile then show the correct data:
http://i.imgur.com/ZeXk6Xz.png
Is this a bug? Is it my fault as a user?
I work with Debian
VAM_test_s.sqlite
<http://osgeo-org.1560.x6.nabble.com/file/n5101983/VAM_test_s.sqlite&gt;
Micha Silver
GIS Consulting
052-3665918
http://www.surfaces.co.il
Sicuramente.
Con i DB occorre fare attenzione alla replicazione degli id. È un mantra da ripetere,
Mai provocare la duplicazipne degli id nelle viste.
Mai provocare la duplicazione degli id nelle viste .
Mai …
A.
Il 05/feb/2014 11:40 “Paolo Cavallini” <cavallini@faunalia.it> ha scritto:
Salve.
Ho seguito la discussione un po’ al volo, ma mi pare che questa nota aiuti a capire
(se no, scusatemi).
Saluti.
manager) don’t care about this since the ROWID is more a convenience. But for QGIS
it’s critical that this column be like a unique primary key.
integers in some way to get a new unique value to be used as the ROWID. That should
Good luck,
Micha
Hello,
changed to false:
I work with Debian
VAM_test_s.sqlite
<http://osgeo-org.1560.x6.nabble.com/file/n5101983/VAM_test_s.sqlite>
Micha Silver
GIS Consulting
052-3665918
Gfoss@lists.gfoss.it
666 iscritti al 22.7.2013
