Salve ho un grosso problema con un progetto elaborato sullo studio dei dati di interferometria satellitare. Ho utilazzato senza problemi il plugin PS Time Series senza problemi, tanto sulla versione Qgis 2.2 che sulla 2.6, ed improvvisamente ha smesso di effettuare l'elaborazione restituendo il messaggio "no time series value found for the selected point".
L'errore restituito pare sia dovuto a OTB. QUALCUNO PUO' AIUTARMI??? E' URGENTISSIMO!!!:
copio e incollo
ERROR|Sat Jan 17 2015 12:20:57|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sat Jan 17 2015 12:20:57|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sat Jan 17 2015 12:20:59
ERROR|Sat Jan 17 2015 12:28:11|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sat Jan 17 2015 12:28:11|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sat Jan 17 2015 12:28:11
ERROR|Sun Jan 18 2015 18:30:58|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Sun Jan 18 2015 18:30:58|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Sun Jan 18 2015 18:30:59
ERROR|Mon Jan 19 2015 01:09:29|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Mon Jan 19 2015 01:09:29|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Mon Jan 19 2015 01:09:30
ERROR|Mon Jan 19 2015 09:05:26|Could not open OTB algorithm: C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\processing\algs\otb\description\TrainImagesClassifier-svm.xml|*ParameterNumber|-elev.default|Default elevation|None|None|0
ERROR|Mon Jan 19 2015 09:05:26|Could not open OTB algorithm: TrainImagesClassifier-svm.xml
Started logging at Mon Jan 19 2015 09:05:30
point".
E' URGENTISSIMO!!!:
Salve.
Secondo me l'errore non c'entra assolutamente niente con il plugin.
A livello del plugin, cosa succede?
Saluti.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
NULLA!!!!!! Anzi, per qualche giorno non vi ho più lavorato perchè ho consegnato il cartaceo. Purtroppo non sapevo neppure che esistesse OTB, figurati se posso pensare che non sia proprio lì l'errore! Ho provato a disinstallere e reinstallare ma non cambia assolutamente nulla!!!
Il 19/01/2015 11:46, Paolo Cavallini ha scritto:
Ciao.
Il 19/01/2015 11:28, andrea.scaglia ha scritto:
Ho elaborato un progetto di studio basato su interferometria
satellitare, con dati ps forniti direttamente da e-geos. Possiedo dei
dati in orbita Ascending e Descending su base CTR ed ECW e quadro frane
Sifrap. Ai dati ho associato delle PALETTE con gli intervalli di
velocità. Ultimamente ho lavorato sulla versione 2.6.1, senza problemi,
ovvero interrogando i punti con il plugin PS Time mi veniva elaborato il
grafico. Da qualche giorno invece compare il messaggio "no time series
value found for the selected point". Se invece carico i dati sulla
versione 1.8 (che però risulta lentissima e non riesce a caricare la
base ecw), l'elaborazione, sebbene lentissima, avviene su tutti i punti.
Il problema è che devo esporre il lavoro al committente e non so più
come fare!!!Per piacere mantieni la conversazione in lista.
Allora:
- l'errore in OTB non c'entra
- con la 2.6.1 ti funzionava, sugli stessi dati
- da poco tempo non ti funziona piu'
Quindi: cosa hai fatto nel frattempo?
Saluti.
Salve.
La magia nera non esiste. Se e' cambiato il comportamento, deve essere
cambiato qualcosa nella tua installazione.
Hai la possibilita' di provare su una macchina pulita, facendo
l'installazione da 0?
Saluti.
RISOLTO!!!!! Dobbiamo rivedere la teoria sulla magia nera! In preda allo sconforto più totale, dopo aver provato di tutto, ho fatto una cosa semplicissima...salvare i file con altro nome. Identico DB, identica posizione, identica Palette, solo un nome diverso: il plugin PS funziona alla perfezione.
Ora mi piacerebbe che qualcuno mi spiegasse il perchè.
Intanto, se qualcuno ha avuto il medesimo problema, questa può essere una soluzione, rozza e spartana ma funzionante.
Grazie Paolo per la pazienza, a risentirci...
Silvia
Il 19/01/2015 13:13, andrea.scaglia ha scritto:
Appena torno provo sul pc di mia figlia e ti faccio sapere!
Sul fatto che la magia nera non esista, non hai preso in considerazione il fatto che vivo a Torino e qui satana è di casa!!
disinstallere e reinstallare ma non cambia assolutamente nulla!!!Salve.
Saluti.
alla perfezione.
qual e' il vecchio, e quale il nuovo nome? Nei vecchi c'e' uno spazio, o
un carattere "strano"?
Se provi a copiare i files rinominati, e rinominare di nuovo i files
copiati con il vecchio nome, il problema si ripresenta?
Saluti.
Provo a fare pure questo, ma dopo averlo presentato mercoledì perchè ho il terrore che la magia nera abbia di nuovo la meglio. Poi ti faccio sapere.
resta il fatto, ribadisco, che con quello stramaledetto nome prima funzionavano. Mah!!!!
alla perfezione.
Ora mi piacerebbe che qualcuno mi spiegasse il perchè.qual e' il vecchio, e quale il nuovo nome? Nei vecchi c'e' uno spazio, o
Saluti.
Dimenticavo...
il vecchio nome è, per fare un esempio di uno sui dieci file:
Bardonecchia_DESC_HI_03_PSP_IFSAR_vel_medie_filtered
quello nuovo
DESC2_FILTR
alla perfezione.
Saluti.
Il 19/01/2015 18:51, andrea.scaglia ha scritto:
Dimenticavo...
quello nuovo
DESC2_FILTR
credo tu sia incappata nel limite di lunghezza del nome dei files (o
percorsi, uno dei trojaj di windoz.
saluti.
"Trojajo" è un eufemismo!
Dimenticavo...
quello nuovo
DESC2_FILTRcredo tu sia incappata nel limite di lunghezza del nome dei files (o
saluti.
Su Linux questo limite non esiste ?
Forse un po' piu' alto ?
A.
Dimenticavo...
quello nuovo
saluti.
