Salve a tutti....
Sto cercando di creare un WMS ma con scarsi risultati!
Il problema sta quando cerco di visualizzarlo (aggiungerlo) in qualche sw
GIS.
L'unico che non mi da problemi e QGIS, mentre in uDIG, gvSIG, ArcGIS 9.2
(tutti all'ultima versione) non riesco
a visualizzare le mie mappe.
di seguito il mapfile:
###########MAPFILE############################
MAP
NAME "WMS-test"
STATUS ON
SIZE 400 300
SYMBOLSET "../ditradata/symbols/symbols35.sym"
EXTENT 2614649 4320194 2653614 4344669
UNITS METERS
SHAPEPATH "../CMS"
IMAGECOLOR 255 255 255
FONTSET "../CMS/font/font.txt"
IMAGETYPE PNG
PROJECTION
"init=epsg:3004" ##required
END
# OUTPUTFORMAT
# NAME jpeg
# DRIVER "GD/JPEG"
# # quality setting: 0 is minimum quality, 100 is maximum quality
# FORMATOPTION QUALITY=70
# # data format
# MIMETYPE "image/jpeg"
# # currently, there is no real grayscale jpeg output available
# IMAGEMODE RGB
# EXTENSION "jpg"
# END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION INTERLACE=OFF
TRANSPARENT OFF
END
OUTPUTFORMAT
NAME png8
DRIVER "GD/PNG"
IMAGEMODE PC256
TRANSPARENT OFF
END
WEB
IMAGEPATH "/mapserver/wms_tmp/"
IMAGEURL "/wms_tmp/"
METADATA
"wms_title" "WMS Demo Server" ##required
"wms_abstract" "Web Map Service"
"wms_onlineresource" "http://debian/cgi-bin/mapserv?" ##required
#"wms_srs" "EPSG:26592 EPSG:3004" ##recommended
"wms_getfeatureinfo"
"http://debian/cgi-bin/mapserv?map=/home/sam/www/WMS/wms.map&"
"wms_featureinfoformat" "text/plain"
# "wms_feature_info_mime_type" "text/html"
END
END
# Start of layer definitions
LAYER
NAME "DEM"
TYPE Raster
STATUS ON
DATA '../CMS/dem.tif'
#MINSCALE 80000
PROJECTION
"init=epsg:3004"
END
METADATA
"wms_title" "Modello digitale del Terreno" ##required
"wms_include_items" "all"
"wms_srs" "EPSG:3004"
END # Metadata
END # Layer
LAYER
NAME "Limiti Amministartivi"
METADATA
"wms_title" "Comuni" ##required
END
TYPE POLYGON
STATUS ON
TRANSPARENCY 45
DATA comu_savuto
TEMPLATE 'dummy'
DUMP TRUE
LABELITEM "NOME_COM"
PROJECTION
"init=epsg:3004" ##recommended
END
CLASSITEM 'NOME_COM'
CLASS
Name 'Limiti'
COLOR 55 245 0
SYMBOL 'square'
OUTLINECOLOR 0 0 0
SIZE 8
LABEL
FONT arial
TYPE truetype
ANTIALIAS false
SIZE 8
COLOR 0 0 0
POSITION cc
PARTIALS FALSE
FORCE true
OFFSET 0 0
#OUTLINECOLOR 0 0 0
END #Label
TEMPLATE 'dummy'
END # Class
# CLASS
# NAME "Comuni"
# STYLE
# COLOR 200 255 0
# OUTLINECOLOR 120 120 120
# END
# END
END # Layer
LAYER
NAME "Rete Stradale"
TYPE line
DATA "strade"
LABELITEM "NOME"
LABELMAXSCALE 10000
PROJECTION
"init=epsg:3004"
END
METADATA
"wms_title" "Strade" ##required
END
CLASS
Name 'strade'
COLOR 51 255 0
SYMBOL 'circle'
LABEL
ANGLE auto
FONT arial
TYPE truetype
ANTIALIAS false
SIZE 8
OUTLINECOLOR 255 255 255
COLOR 0 0 0
POSITION uc
PARTIALS FALSE
FORCE false
OFFSET 0 0
#OUTLINECOLOR 0 0 0
END #Label
SIZE 4
TEMPLATE dummy
END # Class
END # Layer
LAYER
NAME "Idrografia"
TYPE line
DATA "elementi_idrici"
STATUS OFF
PROJECTION
"init=epsg:3004"
END
METADATA
"wms_title" "Elementi Idrici" ##required
END
# CLASSITEM toponimo
# CLASS
# NAME "Fiume Crati"
# EXPRESSION "Fiume Crati"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
# CLASS
# NAME "Fiume Amato"
# EXPRESSION "Fiume Amato"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
# CLASS
# NAME "Fiume Tacina"
# EXPRESSION "Fiume Tacina"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
# CLASS
# NAME "Fiume Savuto"
# EXPRESSION "Fiume Savuto"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
# CLASS
# NAME "Fiume Neto"
# EXPRESSION "Fiume Neto"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
# CLASS
# NAME "Fiume TRIONTO"
# EXPRESSION "Fiume TRIONTO"
# COLOR 0 0 255
# SYMBOL 'circle'
# SIZE 4
# TEMPLATE dummy
# END # Class
CLASS
Name 'elementi_idrici'
COLOR 0 0 255
SYMBOL 'circle'
SIZE 2
TEMPLATE 'dummy'
END # Class
END # Layer
LAYER
NAME "Sentieri"
METADATA
"wms_title" "Sentieri naturalistici" ##required
END
TYPE LINE
STATUS ON
DATA sentieri
TEMPLATE 'dummy'
PROJECTION
END
CLASSITEM "RIF"
CLASS
NAME 'A3'
EXPRESSION "A3"
STYLE
COLOR 0 0 0
SYMBOL 'punkt'
SIZE 7
END
STYLE
COLOR 255 255 0
SYMBOL 'punkt'
SIZE 5
END
STYLE
COLOR 0 0 0
SYMBOL 'line-a3'
SIZE 1
END
END
CLASS
Name "Sentieri"
STYLE
COLOR 255 50 0
SYMBOL punkt
SIZE 5
END
STYLE
COLOR 255 255 0
SYMBOL line-a3
SIZE 1
END
END
END # Layer
LAYER
NAME "CAI"
#CONNECTION "user=postgres dbname=cms host=localhost port=5432"
#DATA "the_geom from (select gid,the_geom,cod_cai from sentieri) as
newtable USING UNIQUE gid USING SRID=26592"
#DATA "the_geom from sentieri"
TYPE POINT
TOLERANCE 10
TOLERANCEUNITS pixels
DATA "marker_gbe"
LABELITEM "CAI"
STATUS ON
TEMPLATE 'dummy'
DUMP TRUE
PROJECTION
"init=epsg:3004"
END
METADATA
"wms_title" "Segnaletica CAI" ##required
END # Metadata
CLASSITEM CAI
CLASS
Name 'marker'
STYLE
#COLOR 0 0 255
SYMBOL '/home/sam/www/SISNCMS/symbol_image/cai.gif'
SIZE 18
END
LABEL
POSITION cc
#COLOR 0 0 0
#BACKGROUNDCOLOR 255 255 255
#BACKGROUNDSHADOWCOLOR 255 0 0
#BACKGROUNDSHADOWSIZE 2 2
BUFFER 0
TYPE truetype
FONT arial
SIZE 8
MAXSIZE 14
#SIZE small
END #Label
TEMPLATE 'dummy'
END # Class
END # Layer
END # Map File
qualcuno sa dirmi dove sto sbagliando?
View this message in context: http://www.nabble.com/WMS---tf3763619.html#a10638759
Sent from the Gfoss mailing list archive at Nabble.com.
