GIS Master Bibliography
Geographic Information Systems Laboratory
Department of Geography
The Ohio State University
Columbus, Ohio
USA
Update Notice No. 2 - December 29, 1993
New Items:
The following items have been added to GIS Master Bibliography
FTP area:
A) International Journal of Geographical Information Systems,
Vol. 7, No. 5 (Sept-Oct, 1993)
B) Mac versions of most of the existing EndNote libraries.
Located in the gis.mac subdirectory.
Comments:
A) My thanks to Dr. Khaled Al-Taha of Louisiana State University
for providing the Mac versions of the EndNote libraries.
B) Please note that the correct IP address for BASTET is given
this time. I regret the difficulties that this caused some of
you.
[The following material will be repeated in every update post-
ing.]
Accessing the GIS Master Bibliography
Access to current files is available via anonymous FTP for
those individuals and organizations having access to the Internet.
Because of copyright restrictions, files will be restricted to
those instances where formal agreements have been signed with the
publishers.
To access the currently available files enter the following
commands:
ftp 128.146.209.34 (this is BASTET.SBS.OHIO-STATE.EDU)
when you are asked to log in, respond with the user name of
anonymous
when you are asked for a password, please respond with your
Internet address.
When the log on operation is completed, change to the
appropriate directory by using one of the following commands:
cd biblio (this places you in the base direc-
tory for the project -- several
ASCII information files are located
here)
cd /biblio/gis.refer (this places you in a directory with
files in REFER (ASCII) format)
cd /biblio/gis.pc (this places you in a directory with
files in EndNote format for the PC)
cd /biblio/gis.mac (this places you in a directory with
files in EndNote format for the Mac)
You may now copy any of the available files. For example, to
copy the ASCII bibliographic entries for the 1992 Spatial Data
Handling Symposium select the gis.refer directory and issue the
command:
get sdh92.refer
FTP also supports the command mget which permits the retrieval of
multiple files using wild card specifications. For example to
retrieve all of the ASCII files dealing with the various Spatial
Data Handling Symposia, select the gis.refer directory and issue
the command:
mget sdh*.*
If you are planning to copy either the PC or Mac versions of the
EndNote binary files, you must issue the following command before
issuing the command to get a copy of the desired file:
binary
After the file(s) have been copied, they should reside in your
default directory on your home machine. To leave the FTP session,
issue the final command:
quit
that returns you to your home machine.
Requests for Information, Comments, etc.
marble.1@osu.edu
Professor Duane Marble
Columbus, Ohio 43210
U.S.A.
Duane F. Marble E-mail: dmarble@magnus.acs.ohio-state.edu
Department of Geography Telephone: (614) 292-2250
Columbus, Ohio 43210 Fax: (614) 292-6213
