Is the old GIS.sh and bash problem solved in 5.0b or do I need to get a
special GIS.sh ? For the moment I get the following error messages when
trying to connect to a location I just created:
/usr/local/grass-5.0b/etc/GIS.sh: g.gisenv: command not found
/usr/local/grass-5.0b/etc/GIS.sh: g.gisenv:command not found
/usr/local/grass-5.0b/etc/GIS.sh: GISDBASE: parameter null or not set
Moritz
Hi Moritz,
it is solved for GRASS 5.x and 4.2.1 and 4.3. I will remove
the message from FAQ.
I guess after compiling you did not run
gmakelinks5
That was it, thank you !
But I believe this info should be "INSTALL" instructions that come with
the source code.
Moritz
Hi Moritz,
gmakelinks5
the source code.
Thanks Moritz,
I have updated the INSTALL in source code (really, it was missing).
> Hi Moritz,
> gmakelinks5
> Cheers
> Markus
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
